Okay, it *almost* works for me, it's sooooo close.
I run Rhubarb, I get an excellent .dat file (I assume it's excellent, it's listing frames with mouth shapes for the frames listed, exactly as expected, sample below), I select my "Mouth" switch layer where all the images are named to match the Rhubarb default and select the .dat file, it places keyframe markers above the audio track and then... nothing. The keyframe markers don't change any of the mouth shapes showing in the scene during playback, the mouth stays at the default.
It *looks* like it's working right up until I hit "Play".
The .dat file looks like this:
MohoSwitch1
1 X
2 B
4 A
6 C
12 B
14 C
17 B
24 E
31 C
32 B
39 C
41 D
and so on.
Any suggestions?
Cartoon Animator to Moho -- Step One: 13.5 Debut, more questions!
Re: Cartoon Animator to Moho -- Step One: 13.5 Debut, more questions!
Disregard.
I remembered reading (probably in these forums) that I had to remove the ".png" from the images in the mouth switch layer, so "A" instead of "A.png".
It worked as advertised, thanks very much!
- Yosemite Sam
Hey, I'm still not sure I understand the process of using Rhubarb for auto lip-syncing in Moho.SimplSam wrote: ↑Fri Oct 27, 2023 5:47 pmFor Moho a 'default' command (-f dat required) will use Hanna Barbera style: A, B, C, D, E, F, G, H, X notation (the expected Switch Layers in Moho need to be labelled as such).
rhubarb -f dat -o output.txt input.wav
You can also specify --datUsePrestonBlair to output Preston Blair style: AI, E, etc, FV, L, MBP, O, rest, WQ. It is exactly the same timings - just changed notation. Can also specify frame rate using --datFrameRate. And add helper input text using -d. The text option didn't really seem to help me!
rhubarb.exe -f dat --datUsePrestonBlair --datFrameRate 25 -d input.txt -o output.txt input.wav
Once you have the Output file, on the Switch Layer go into Layer Properties > Switch > Select audio sync source > Switch Data File, and the select your output file, then [OK/Apply]. You will have to import the Audio separately if you want to hear/see that.
I've watched the video for using it in spine, but cannot find anything for Moho. I understand the specific labeling system for mouth shapes in Moho and I've downloaded Rhubarb, but have no idea how to proceed.
Would be grateful for any advice.
Thanks!
Jimmy Mills
Some of my Moho Pro work.
My Demo Reel: https://youtu.be/_kSCno4Wd3c?si=gNT7d27R7sM4jjqq
Buddies Ep 4: https://youtu.be/f8Zbzo2mpHA?si=4EyxhBOrgOxkDoSO
So... for Moho this is a command line tool, and it has no graphical interface. So you could run it as:
where:
1. input.wav is the Source audio
2. output.txt is the Moho dat file
then in Moho - on the Switch Layer open Layer Properties > Switch > Select audio sync source > Switch Data File, and the select your output file (Moho dat file), then [OK/Apply].
where:
