gradient issue (solved)
Re: gradient issue (solved)
ah :oops: - totally forgot about your shape tool! Thanks for the reminder!
Rai López
Re: gradient bug
Post by Rai López »
hayasidist wrote: ↑Fri Apr 29, 2022 2:45 am Indeed --- If we (still) had the ability to make many shapes using the same set of points it would be even easier to set up -- e.g. 3 shapes over the base head - 1 "bg" fill; 2 gradients. :D
And don't forget we are still able to do it natively, it just requires you have selected (for example) an extra temporally created point when creating the shape. I do it all the time at shapes creation time, normally simply having a reusable dummy curve made of two points at any place in viewport with this only purpose that I simply delete afterwards. I'm aware this is well known, but I thought that for some less experienced people it could worth a mention just in case...
