Does the wind simulator have an effect on particles?
MrMiracle77
Re: Does the wind simulator have an effect on particles?
Post by MrMiracle77 »
The min and max along the top bar should let you set the scale range. It's just not a part of the drop-down tool for some reason.
- Dave
(As Your GM)
OOOOOOOoooooooh! Duh.
I was playing around with that option too and it's purpose didn't click for me at the time, probably because it was separated from the other options. (And I probably needed sleep.)
Thanks for pointing this out! The Scatter Brush is much more useful to me now. :D
I reported this as a 'missing' option last night, but maybe the request should be to move 'Scale Jitter' to the panel with the other Scatter Brush options. Or at least label it 'Scale Jitter'.
Here's an example of using two particle layers with different settings, using Dennis' example.
https://www.mediafire.com/file/xzhzmqbm ... 9.zip/file
