Let's suggest new API features
Re: Let's suggest new API features
SimplSam wrote: Sat Mar 13, 2021 9:11 am Modifier keys
Something else that would be welcomed is if modifier keys were recognised when the tool button was invoked. Even extending to recognising Right Click.
This would allow for options like settings mode and advanced mode etc etc..
that was formally requested back in 2018 ... let's hope the new team are a bit more responsive ...
[Edit]:
I'll reignite that particular flame after 13.5 hits the streets. I think the dev team has got its hands full enough right now ...
KuzKuz
Post by KuzKuz »
Yes Yes Yes +++
Even if just the Alt modifier were available for toolbar buttons, just like we have for GUI buttons: http://mohoscripting.com/methods/1051
Lukas
Post by Lukas »
Stan wrote: Fri Feb 19, 2021 8:40 pm
  • Add the moho object to the UpdateWidgets and HandleMessage methods of the non-modal dialogs.
Yes yes yes, this would create tons of possibilities for new tools.
SimplSam wrote: Sun Feb 28, 2021 4:35 am Expressions
Yesss! This would make some layerscripts obsolete and would be a much user friendlier way to expand rigging possibilities.
synthsin75 wrote: Mon Mar 15, 2021 8:51 amEven if just the Alt modifier were available for toolbar buttons, just like we have for GUI buttons: http://mohoscripting.com/methods/1051
😳 I didn't even know this was possible!!! Definitely going to implement this right away. It would be nice to have all of them available.
Lukas
Post by Lukas »
Maybe I'm not understanding this correctly, but I just read some code and I think it's actually possible to add the moho object to the UpdateWidgets method of a non-modal dialogue... Check out the LM_Set_Origin.lua tool. It actually creates a modeless window in DoLayout, but the code is commented out.
	--if (self.layerSettingsWnd == nil) then
	--	self.layerSettingsWnd = LM_LayerSettingsDialog:new()
	--	self.layerSettingsWnd:DoModeless()
	--end
And then the tool also contains:
-- register the layer window to be updated when changes are made
table.insert(MOHO.UpdateTable, LM_LayerSettingsDialog_Update)
Which actually triggers the dialog to update during updates, and it passes moho...?
function LM_LayerSettingsDialog_Update(moho)
You technically can pass moho to any window through the d.moho = moho variable. But that window will not be able to get changes from Moho, like the current frame, if changed since the window was invoked. You also have to pass any moho methods through their own variable. Assigning d.moho doesn't allow self.moho.layer to work, but assigning d.layer = moho.layer lets self.layer work. So you have to assign every method you want to use. As long as the new() function can accept moho, like new(moho), this works.
Lukas
Post by Lukas »
synthsin75 wrote: Sat Apr 10, 2021 3:04 pmBut that window will not be able to get changes from Moho, like the current frame, if changed since the window was invoked.
Well, the dialog in LM_SetOrigin actually gets changes from Moho after being invoked. Or is that also possible with the method you just mentioned? I think I'm in over my head here...
Lukas wrote: Sat Apr 10, 2021 3:16 pm
I have to investigate that further. I've never seen something like a table.insert called outside of a function, which would insert it when the tool was loaded by Moho.
Lukas wrote: Sat Apr 10, 2021 2:43 pm Maybe I'm not understanding this correctly, but ... the LM_Set_Origin.lua tool ... contains:
Now that is interesting -- the table MOHO.UpdateTable and the function MOHO.RunUpdateTable have been there since at least 12.5 -- I haven't dug deeper into the past. The function is described briefly in http://mohoscripting.com/lm_utilities
This is the code...
MOHO.UpdateTable = {}
function MOHO.RunUpdateTable(moho)
	for i, func in ipairs(MOHO.UpdateTable) do
		func(moho)
	end
end
But it does indeed suggest that the MOHO.UpdateTable is a list of functions to be run "when changes are made" and that they are passed an instance of moho -- although right now I don't know what exactly will trigger the MOHO.RunUpdateTable function to run, and when an entry is removed from the table.
I've finally done some more on this ...
It's dead easy to put a routine in the table and it does get run when the user clicks on a new tool or moves the timeline (and, I guess, similar events).
function HS_ForUpdate(moho)
	local t = type (moho.frame)
	Print ("I'm here!!", t)
end
	table.insert(MOHO.UpdateTable, HS_ForUpdate)
However, the "moho" that the called routine gets doesn't seem to be the same as I was expecting - the above reports t as "nil" ... maybe something wrong with the way I'm setting things up -- but right now I'm at a bit of a brick wall.
Lukas
Post by Lukas »
hayasidist wrote: Thu Aug 05, 2021 2:10 amHowever, the "moho" that the called routine gets doesn't seem to be the same as I was expecting - the above reports t as "nil" ... maybe something wrong with the way I'm setting things up -- but right now I'm at a bit of a brick wall.
I've also been dabbling and it's all very confusing...
I also touched that brick wall a lot, and moho.layer == nil fires both true and false at the same time. (Obviously not at the same time, but the function fires twice I guess)
I did get something to work which seemed impossible before. And I imagine it's possible to maybe not have the window be local in a tool, but global in a utility? (I don't even know what I'm talking about, but hopefully one of you does) 😅
Save this as a tool:
-- Provide Moho with the name of this script object
ScriptName = "LK_Experiment"
LK_Experiment = {}
LK_Experiment.BASE_STR = 2325
function LK_Experiment:Name()
	return "LK_Experiment...Name"
end
function LK_Experiment:Version()
	return "0.1"
end
function LK_Experiment:Description()
	return "LK_Experiment...Description"
end
function LK_Experiment:Creator()
	return "Lukas Krepel, Frame Order"
end
function LK_Experiment:UILabel()
	return "LK_Experiment...UILabel"
end
function LK_Experiment:ColorizeIcon()
	return true
end
-- Recurring values
LK_Experiment.matrix = LM.Matrix:new_local()
LK_Experiment.experimentalWindow = nil
-- The guts of this script
function LK_Experiment:OnInputDeviceEvent(moho, deviceEvent)
end
function LK_Experiment:OnMouseDown(moho, mouseEvent)
end
function LK_Experiment:OnMouseMoved(moho, mouseEvent)
end
-- Layer Settings dialog
local LK_ExperimentDialog = {}
LK_ExperimentDialog.CHANGE = MOHO.MSG_BASE
LK_ExperimentDialog.XPOS = MOHO.MSG_BASE + 1
function LK_ExperimentDialog:new()
	local d = LM.GUI.SimpleDialog("Experimental Window", LK_ExperimentDialog)
	local l = d:GetLayout()
	l:PushH()
		d.frame = LM.GUI.DynamicText("Frame 00000", 80)
		l:AddChild(d.frame, LM.GUI.ALIGN_LEFT)
		-- * LM.GUI.Slider(length, vertical, showTicks, msg, resizingMode)
		d.slider = LM.GUI.Slider(200, false, false, LK_ExperimentDialog.CHANGE, LM_FOLLOW_LEFT)
		l:AddChild(d.slider)
	l:Pop()
	l:PushH()
		l:AddChild(LM.GUI.StaticText("Layer X translation:"))
		d.pX = LM.GUI.TextControl(0, "00.0000", LK_ExperimentDialog.XPOS, LM.GUI.FIELD_FLOAT)
		l:AddChild(d.pX, LM.GUI.ALIGN_LEFT)
	l:Pop()
	return d
end
function LK_ExperimentDialog:Update(moho)
	if (moho.layer == nil) then
		-- print ("moho.layer == nil (?!)")
		return
	end
	-- print ("moho.layer ~= nil (WHAT?)")
	self.frame:SetValue("Frame "..moho.frame)
	self.slider:SetRange(moho.document:StartFrame(), moho.document:EndFrame())
	self.slider:SetValue(moho.frame)
	local layer = moho.layer
	self.pX:SetValue(layer.fTranslation.value.x)
end
function LK_ExperimentDialog:OnOK()
	LK_Experiment.experimentalWindow = nil -- mark the window closed
end
function LK_ExperimentDialog_Update(moho)
	if (LK_Experiment.experimentalWindow) then
		LK_Experiment.experimentalWindow:Update(moho)
	end
end
table.insert(MOHO.UpdateTable, LK_ExperimentDialog_Update)
-- Tool options - create and respond to tool's UI
LK_Experiment.CHANGE = MOHO.MSG_BASE
LK_Experiment.XPOS = MOHO.MSG_BASE + 1
function LK_Experiment:DoLayout(moho, layout)
	if (self.experimentalWindow == nil) then
		self.experimentalWindow = LK_ExperimentDialog:new()
		self.experimentalWindow:DoModeless()
	end
end
function LK_Experiment:UpdateWidgets(moho)
	if (self.experimentalWindow) then
		self.experimentalWindow:Update(moho)
	end
end
function LK_Experiment:HandleMessage(moho, view, msg)
	if (msg == self.CHANGE) then
		-- * Slide to new frame:
		local newFrame = LK_Experiment.experimentalWindow.slider:Value()
		moho:SetCurFrame(newFrame)
	end
	if (msg == self.XPOS) then
		-- * Prep undo:
		moho.document:PrepUndo(moho.layer, true)
		moho.document:SetDirty()
		-- * Key layer translation:
		local layerPos = moho.layer.fTranslation:GetValue(moho.frame)
		layerPos:Set (LK_Experiment.experimentalWindow.pX:FloatValue(), layerPos.y, layerPos.z)
		moho.layer.fTranslation:SetValue(moho.frame, layerPos)
		-- * Update timeline:
		moho:UpdateUI()
	end
end
It will popup a dialog that is able to get and set the current frame of the timeline. And also get and set the translation of the current layer.
If you select a different tool, the dialog becomes silent, until you reselect the tool again.
But... If you add handle message and update widget functions to the ones of another tool, that tool is also able to keep the window active!
function LM_SomeOtherTool:HandleMessage(moho, view, msg)
function LM_SomeOtherTool:UpdateWidgets(moho)
	end
Lukas
Post by Lukas »
Okay, here is a simpler version...
Add this as a button or menuscript:
LK_Experiment = {}
end
	return "0.1"
end
end
end
end
	return true
end
	l:PushH()
		d.slider = LM.GUI.Slider(200, false, false, LK_Experiment.CHANGE, LM_FOLLOW_LEFT) -- * LM.GUI.Slider(length, vertical, showTicks, msg, resizingMode)
	l:Pop()
	l:PushH()
		d.pX = LM.GUI.TextControl(0, "00.0000", LK_Experiment.XPOS, LM.GUI.FIELD_FLOAT)
	l:Pop()
	return d
end
		return
	end
end
end
	if (experimentalWindow) then
	end
end
LK_Experiment.MSG_BASE = 	2000 -- * Might conflict with other tools!
LK_Experiment.CHANGE =		MOHO.MSG_BASE + LK_Experiment.MSG_BASE + 0
LK_Experiment.XPOS =		MOHO.MSG_BASE + LK_Experiment.MSG_BASE + 1
function LK_Experiment:Run(moho)
	if (experimentalWindow == nil) then
	end
end
	-- print ("msg "..msg)
		local newFrame = experimentalWindow.slider:Value()
	end
		-- * Prep undo:
		layerPos:Set (experimentalWindow.pX:FloatValue(), layerPos.y, layerPos.z)
		moho:UpdateUI()
	end
end
And add this to all other tools:
	function LM_AddPoint:HandleMessage(moho, view, msg)
	if msg >= MOHO.MSG_BASE + LK_Experiment.MSG_BASE then -- * Might conflict with the original tools intentions!
		return
	end
Because handlemessage is forwarding the msg, I've added a msg_base value to the script. But I'm not exactly sure if this is a terrible idea:
I can imagine a modal window that simply controls smartbonedials. Or that script I once wrote (I'm sure it's somewhere on this forum) that toggles bones by color. It would be nice to be able to just have it open and use it with any tool.
The experimental menu script just throws an error from the AddPoint tool. Likely due to that MSG_BASE.
Lukas
Post by Lukas »
synthsin75 wrote: Thu Aug 05, 2021 9:37 am The experimental menu script just throws an error from the AddPoint tool. Likely due to that MSG_BASE.
Ahh, yes, because the addpoint tool's handlemessage checks for "elseif (msg >= self.SELECTITEM) then" it will likely always trigger a part of that code which is not supposed to run and throw an error... I'm don't really understand how MSG_BASE works and what its min/max values are. There's probably no sure way to make sure the msg integers of the modal window won't overlap with the tools without modifying some of them.
This works, but is also probably problematic:
		return
	end
Lukas wrote: Sat Apr 10, 2021 2:43 pm Check out the LM_Set_Origin.lua tool ... the tool also contains:
has anyone found / got access to the code for the LM_LayerSettingsDialog_Update function? How that handles the "moho" param would be very illuminating!
I've not found it in the "Resources" directory from the installation so I'm guessing it isn't part of any LUA tool script to which we should have access.
