Disable Space Bar While Drawing
Re: Disable Space Bar While Drawing
I'm trying to remember how I had my Companion setup. I think it was something like:
- Assign undo and redo to left and right rocker buttons.
- Lower rocker is Shift.
- Lower two buttons are Alt and Ctrl
- Top button was to switch screens when the tablet was converted from mobile computer to desktop tablet mode. You'll probably want this if you use the Wacom Cintiq on a desktop that also has a regular monitor.
- Second from Top was probably set to Esc or 'Drop Selection' (i.e., points, shapes or bones.)
Something like that anyway. I can fire up the Companion later to double-check.
For everything else, I originally used Wacom's On-Screen Control (OSC) panel, which is an eight button on-screen panel you can configure to send almost any Moho command. If you have a Wacom tablet, OSC panels can be set up from within the Wacom Control panel. It's possible to make custom OSC panels for any of your programs and you can even make multiple panels to use for a single program.
However, for me, the problem with Wacom's OSC was that I had to create almost 3 full panels just for Moho, which was a bit much and they used up a ton of screen space, so I created MQC to hold all of my frequently used Moho commands in a single compact panel. MQC even does a couple of things I couldn't do with Wacom's OSC panels.
Anyway, MQC works great with a stylus because it's much easier to click on an ever present button than it is to dig around Moho's menus and tool options for hidden buttons. And MQC isn't just for tablet users, it works great with a mouse and keyboard too.
I'm recording an intro video tonight and, if all goes well, I'll make MQC available for download tomorrow.
BTW, you're running Moho on Windows right? MQC only works on a Windows computer. (Tested on Win 7 and up.) Sadly it won't run on a Mac but I'm sure MQC can be replicated by a Mac user. I'll make the uncompiled script available for any Mac user who want to adapt it.
Here's a comparison between the MQC and Wacom OSC. The top panel is MQC and the lower three are OSC:
I'll explain the workflow in the video.
drumlug13 wrote: ↑Sat Jun 22, 2019 12:04 pm It's the whole getting used to drawing with a tablet that has everything sideways
It's just as well. I just checked, and I didn't find any way to stop Moho from playing by script. I can keep it on frame zero (even without setting the start and end to zero), but it's technically still playing and slowing things down until you hit space again.
drumlug13
Post by drumlug13 »
synthsin75 wrote: ↑Sat Jun 22, 2019 7:33 pm
Thanks for taking the time to look into it Wes.
Greenlaw wrote: ↑Sat Jun 22, 2019 7:06 pm Here's a comparison between the MQC and Wacom OSC. The top panel is MQC and the lower three are OSC:
Wow... I had no idea that OSC was even a thing. Can't wait to see this. And yes, I am using a Windows pc
Adam
Sorry, falling behind schedule. I don't want to release MQC until the accompanying 'Animaker' video is ready, which was recorded this weekend but I need to finish editing and add a title card. Will hopefully upload in the next couple of evenings.
drumlug13
Post by drumlug13 »
Don't sweat it. Looking forward to it but take your time.
Adam
Thanks for your patience. I actually have a handful of other 'Moho' videos I'm trying to finish and post, but ATM I'm giving this one priority.
drumlug13 wrote: ↑Sun Jun 23, 2019 6:16 am Wow... I had no idea that OSC was even a thing...
Come to think of it, I probably had an Express Key on the Companion assigned to open the Moho OSC. That is, until the number of Moho OSC panels I needed grew. At one point, I even considered making an OSC to open other OSC panels...it was then I decided OSC was inadequate for the way I use Moho, and MQC was born.
That said, OSC is still pretty cool and I like to use it for other programs where I don't need as many buttons.
highball326
Post by highball326 »
if you are referring to the "inability" to use the spacebar to move the canvas but get the play action, well... check this out... if you press the spacebar, use the mouse clicked to move the screen BEFORE you release the spacebar and the play action will be cancelled. pressing and releasing the spacebar without using the mouse will cause a play action. hope that helps ya!
SuperSGL
Post by SuperSGL »
I love being able to use the right mouse button for panning but I think I would opt out of it for a context sensitive menu. I still click it for that reason and it just moves the screen :(
It also screws me up when I'm drawing in other programs I keep trying to right click to move the canvas and it asks if I want to move or copy :roll:
I think the space bar would be better served for moving canvas and right mouse for a menu (I'm also good with a Shift + Spacebar for 'Play')
Norman McLaren
My Animations
ImpMontezuma
Post by ImpMontezuma »
For me, the space playing the animation is the most annoying thing about moho. Yes, I know it would be easier to use the right click to move the screen and forget the space bar, but telling that for my photoshop trained brain is not easy. I do it all the time without even noticing. Also, is really that hard for the developers to add an OPTION to turn off the space playing the animation? It doesn't even need to be off by default, just gives us an option to turn that feature off.
It only does that if you tap the space bar.
If you press and hold the space bar, Moho works in 'grabber' mode just like in Photoshop.
Moho's space bar behavior is consistent with how the space bar works in Adobe After Effects too: tap to play, press-and-hold for the grabber. It just takes a little practice to get used to it.
staticfuzz
Post by staticfuzz »
I find it quite frustrating too, it would be great to disable or be able to edit it ie. press shift + spacebar.
The important difference between the spacebar behaviour in Moho vs other software is that in Moho frame zero is where you create, and the timeline is where you animate. That's a great system that gives a lot of flexibility in animation but....
If at some point you've hit the spacebar while your supposed to be working at frame zero, you might end up in the timeline without realizing it and your work starts getting unintentially keyed...particularly frustrating if your working with styles at the time...not unfixable, but time consuming and frustrating.
So it's the frame zero vs animating in the timeline, that makes the spacebar behaviour particularly frustrating.
I am teaching animation at university and many students find this frustrating too, because they are used to using the spacebar to move around the canvas in other software. That muscle memory is hard to fight when you are constantly working between software.
Maestral
Post by Maestral »
I believe all of us encountered this "space bar" mishap but perhaps it could be solved with some visual "hint" - as in a different colour for the timeline, while on kf 0?
It works just fine for other colour changes on the timeline - relative keyframing changes it to red (i.e.), so perhaps we could have it dimmed out on kf0?
To be honest, I don't even use the space bar for navigation; I use the right-mouse button.
For navigation...
Panning = RMB
Rotate = Ctrl+RMB
Zoom = Shift+RMB
For me, this is an easier combo to remember, and I don't risk hitting the space bar to play the timeline.
I only use the spacebar for playback, which is consistent with many timeline-based programs, such as video editing, compositing, audio recording, and animation.
Maestral
Post by Maestral »
It could easily be just me and the way I understood the issue - as in accidental pressing of the space bar.
I'm quite familiar with your approach, but from time to time, I don't move the playhead by mouse all the way to the kf0. If I'm jumping back and forth within the first 12-24fr (i.e.). In my case, it happens quite rarely, but there must be more scenarios, both intentional and accidental.
Having some visual change on the timeline could help spot it on time. The mentioned relative keyframes and actions already have it. Would this one more be too much? If it's not the change of the background colour, perhaps some sort of frame around the TL box; perhaps a UI colour overlay; keyframes dimmed out or perhaps not even shown...?
I'm aware it may sound like overkill but this is not the first time I've noticed the same issue has been mentioned. This way or another.
