Wow, thanks! I'll check this out when I get home.synthsin75 wrote:Here's code that gets both next and last keyframe (point motion here), whether the current frame is keyed or not:Code: Select all
local pos = 1 local neg = -1 local frame = moho.frame local ch = moho.layer:Channel(2, 1, moho.document) if (ch:GetKeyWhen(ch:GetClosestKeyID(frame)) ~= frame) then neg = 0 end local nextKeyframe = ch:GetKeyWhen(ch:GetClosestKeyID(frame)+pos) local lastKeyframe = ch:GetKeyWhen(ch:GetClosestKeyID(frame)+neg) print("nextKeyframe = "..nextKeyframe.."\n".."lastKeyframe = "..lastKeyframe)
Two scripts for you: "Maintain pose" and "Toggle visibility"
lehtiniemi
Re: Two scripts for you: "Maintain pose" and "Toggle visibil
lehtiniemi
I can't get this to work. Despite what I give as pos/neg, it always returns the closest previous key, never the next. I can't control the direction... What could it be?
- hayasidist
How I'd go about this:
idOfKey = AnimChannel:GetClosestKeyID(when) -- the id of the key at or before "when"
later = idOfKey + 1 -- the id of the key later than "when"
frameOfKey = AnimChannel:GetKeyWhen(id)
use the above to get the key ids at the start and end of the frame range you want
e.g. between frames 15 and 25:
AnimChannel:GetClosestKeyID(15) will give you a key at or before 15 -- get its frame - if it's at 15 you have it; if not add one to keyId - make sure it's a valid keyId- get that id's frame, check it's not more than 25 - and that's the "earliest in timeline in range"
AnimChannel:GetClosestKeyID(25) will give you a key at or before 25 -- get its frame - if it's at 25 you have it; if not, check it's not less than 15 and that's the "latest in timeline in range"
there might not be a key in range; or earliest and latest may well be the same key of course!
for the whole timeline:
latest in range is the id of the key at AnimChannel:Duration() (should be AnimChannel:CountKeys()-1)
earliest in range is the id of the key at frame 0 (should be 0)
if there's only one key then it'll be at frame 0.
to go backwards between two key ids start at "latest in range" and subtract 1 from that until you get to "earliest in range"
to go forwards between two key ids start at "earliest in range" and add 1 to that until you get to until you get to "latest in range"
using AnimChannel:GetKeyWhen(keyId) as you go to find the key's frame
(and I'm sure I don't actually need to say this, but take care if you're moving keys as you go ...
You shouldn't have to change the pos/neg values. Just use the one you need to get the direction you want.lehtiniemi wrote:I can't get this to work. Despite what I give as pos/neg, it always returns the closest previous key, never the next. I can't control the direction... What could it be?
Previous keyframe:
local neg = -1
neg = 0
end
print("lastKeyframe = "..lastKeyframe)
local pos = 1
print("nextKeyframe = "..nextKeyframe)
The only thing you may need to change is the frame value, if you are evaluating it from somewhere other than the current frame.
lehtiniemi
Ah sorry I wrote unclearly. But to me it seems that GetClosestKeyID only looks for current frame and before it. It doesn't seem to look forwards in timeline, always backwards. At least I couldn't make it do so.synthsin75 wrote:You shouldn't have to change the pos/neg values. Just use the one you need to get the direction you want.lehtiniemi wrote:I can't get this to work. Despite what I give as pos/neg, it always returns the closest previous key, never the next. I can't control the direction... What could it be?
Previous keyframe:Next keyframe:Code: Select all
local neg = -1 local frame = moho.frame local ch = moho.layer:Channel(2, 1, moho.document) if (ch:GetKeyWhen(ch:GetClosestKeyID(frame)) ~= frame) then neg = 0 end local lastKeyframe = ch:GetKeyWhen(ch:GetClosestKeyID(frame)+neg) print("lastKeyframe = "..lastKeyframe)Code: Select all
local pos = 1 local frame = moho.frame local ch = moho.layer:Channel(2, 1, moho.document) local nextKeyframe = ch:GetKeyWhen(ch:GetClosestKeyID(frame)+pos) print("nextKeyframe = "..nextKeyframe)
GetClosestKeyID does only get either the current frame, if keyed, or the last. But it returns an ID. Keyframe IDs are chronological, so if the current frame ID is 16, the next later keyframe ID is 17. My code uses the pos/neg to determine the direction we're looking by ID. Only after getting the next or last keyframe ID do we give that to GetKeyWhen to get the frame. Does it help to write it like this:lehtiniemi wrote:Ah sorry I wrote unclearly. But to me it seems that GetClosestKeyID only looks for current frame and before it. It doesn't seem to look forwards in timeline, always backwards. At least I couldn't make it do so.
local pos = 1
local nextKeyID = ch:GetClosestKeyID(frame)+pos
local nextKeyedFrame = ch:GetKeyWhen(nextKeyID)
print("nextKeyedFrame = "..nextKeyedFrame)
lehtiniemi
Oh, now I get it! Genious! Thank you! In addition, there probably has to be a check that the ID isn't bigger than the amount of keyframes?synthsin75 wrote:GetClosestKeyID does only get either the current frame, if keyed, or the last. But it returns an ID. Keyframe IDs are chronological, so if the current frame ID is 16, the next later keyframe ID is 17. My code uses the pos/neg to determine the direction we're looking by ID. Only after getting the next or last keyframe do we give that to GetKeyWhen to get the frame. Does it help to write it like this:lehtiniemi wrote:Ah sorry I wrote unclearly. But to me it seems that GetClosestKeyID only looks for current frame and before it. It doesn't seem to look forwards in timeline, always backwards. At least I couldn't make it do so.
local pos = 1 local frame = moho.frame local ch = moho.layer:Channel(2, 1, moho.document) local nextKeyID = ch:GetClosestKeyID(frame)+pos local nextKeyedFrame = ch:GetKeyWhen(nextKeyID) print("nextKeyedFrame = "..nextKeyedFrame)
Yeah, off-hand, I'd assume a HasKey(when) check would work.lehtiniemi wrote:Oh, now I get it! Genious! Thank you! In addition, there probably has to be a check that the ID isn't bigger than the amount of keyframes?
if (ch:HasKey(frame+pos)) then
lehtiniemi
Thank you so much again. I know I ask alot, I'm really greatful for your help...!synthsin75 wrote:Yeah, off-hand, I'd assume a HasKey(when) check would work.lehtiniemi wrote:Oh, now I get it! Genious! Thank you! In addition, there probably has to be a check that the ID isn't bigger than the amount of keyframes?
HardikLakhalani
I'm that someone you helped. But Its not working with multiple layers, When selecting 2 or more layers, It applies only on first selected layer. Can you update this script to v1.1 ?lehtiniemi wrote: TOGGLE VISIBILITY
The script toggles the current visibility state for the layer: if it's visible, it becomes hidden and vice versa. "Automated layer effects" is automatically enabled for the selected layer. If the new visibility state is the same as in previous frame (=layer visibility state doesn't change), the keyframe is automatically removed.
Makes animating visibility a LOT faster than with the built-in functions (unless there's something I've missed), especially when the "Automated layer effects" isn't enabled and you animate visibility for the first time in the project.
Installation
Copy both .lua and .png files to the tool-folder.
The buttons appear in "Other"-group after restart.
Download both here:
http://www.juhanalehtiniemi.com/tmp/JL_ ... cripts.zip
