Anime Studio Pro 11.2 is here. Update now!
Re: Anime Studio Pro 11.2 is here. Update now!
Just got a mail announcing an update for Debut.
- Víctor Paredes
11.2 is for both Debut and Pro.Lebostein wrote:Update for Debut planned?
That's the way I setup the brushes and line width for that character. The original designed character had this kind of dirty look and I tried to reproduce it. It rendered the same way in 11.0.herbert123 wrote:Is it just me, or is there an issue with terrible output quality?
This is the demo character exported as a PNG with anti-aliased edges and extra-smooth images. It looks dreadful.
My apologies if this is dead obvious and I've missed it but . .
Has there been an OS X requirement update since v11.0?
herbert123
I just came across this today myself but in an image texture I was using. I am not sure what it is causing it but it is quite unusable the way it is.
D.K
D.K
My store on Renderosity:
Thanks for bugs fixing and special thanks for bone snapping!
quality is really bad but its still kinda neat
that sketch bone tool >>>>>>>>>>>>>
took me forever to rig a natural looking "wrecking ball"
this takes 3 seconds
quick example
Just updated. Are there tutorials for these new features? The readme doesn't go into much depth.
- Víctor Paredes
Yes, you can find them here:madriver wrote:Just updated. Are there tutorials for these new features? The readme doesn't go into much depth.
viewtopic.php?f=5&t=28528
PS: I will add this link to the first post too.
- Francis Seven
Have the quality output issues been fixed? I'm looking forward to buying this but not if the output will be unusable.
Can you be more specific. I had seen some chattering in 11.1 with rigged bitmap art that only appeared in final rendering but that issue appears to be fixed in 11.2. Is that what you mean? If so, then yes.
- Francis Seven
Hi,Greenlaw wrote:Can you be more specific. I had seen some chattering in 11.1 with rigged bitmap art that only appeared in final rendering but that issue appears to be fixed in 11.2. Is that what you mean? If so, then yes.
I was asking about the things mentioned by herbert123, DK and specialo earlier in the thread.
Ah, got it.
FWIW, I haven't seen any rendering problems with 11.2 yet. As mentioned previously, I saw 'chattering' in certain setups in 11.1 but that seems to be fixed in 11.2. At work we rig characters using bitmap layers and vector layers, and so far both types of scenes are rendering nicely here. The couple of times I thought I was seeing a render issue, it turned out to be 'user error'. (Usually, just forgetting to update my Layer Comps after adding new layers.)
By no means am I dismissing what others may be seeing. I'm just saying I haven't personally run into those problems yet. That 'edge tearing' result looks really weird--almost like video interlacing was enabled but I don't think Anime Studio even has that option. I would suggest submitting problem scenes to the developers for them to look at.
G.
G.
slice11217
Same in preview.
I noticed this too. Any word on a fix yet? -Not good for professional work!
slice11217
Yeah, I noticed that if you do a render there is some funky antialiasing on the edges where a shape meets blank background. Perhaps there's an issue with alpha rendering? -DEFINITELY needs to be fixed!slice11217 wrote:herbert123 wrote:Is it just me, or is there an issue with terrible output quality?
Same in preview.
