MohoScripting.com - unofficial Moho scripting documentation
Re: ASLua.com - unofficial Anime Studio scripting documentat
I don't know what hosting service Stan may be using, but I think he lives in Russia. Your IT may have blacklisted Russian ISPs?
No, Wes, that shouldn't be the issue. I'm using hostdeal.com, and I believe the servers are either in Canada or Northern US.
It may be a browser cache issue, or a network issue, I hope the IT guy can answer that.
BTW, I'm originally from Soviet Union (Ukraine), but I live in Massachusetts for the last 15 years.
Thanks Stan, I'm not sure I ever knew that.
- strider2000
I was looking over some code and just wondering if any of the doc tools
http://lua-users.org/wiki/DocumentingLuaCode
are being used to create the unofficial Anime Studio scripting doc or is it done manually. I find it very helpful at times. So thank you.
My thought springs from want to create doc for my own scripts. I'd like to use something like javadoc, and LDoc looks pretty good
https://github.com/stevedonovan/LDoc
http://stevedonovan.github.io/Penlight/api/index.html and
http://stevedonovan.github.io/winapi/api.html
are examples of the output.
While I'm at it, does anyone else use github for their scripts? Might be an easy way to collaborate.
- hayasidist
when I post examples on ASLua they're generally cut and paste from whatever I was working on.
more about the site, and how to contribute to it should you so desire, is here: http://www.kelleytown.com/forum/animato ... IC_ID=3178
Re: MohoScripting.com - unofficial Moho scripting documentat
ASLua.com is now MohoScripting.com
Does anyone know where I can get the Swiss army bones script?
- hayasidist
it's here. http://www.kelleytown.com/forum/animato ... IC_ID=2369 but you might need to get a (free) log on to that site
Wow, that's amazing, Stan! I had no idea you planned to take that script generator tool so far. This will save a ton of time.
Great job!
Great job!
Thanks Wes! Please give it a try, any feedback is highly appreciated.
- hayasidist
and - if you can just add a button that will read my mind and write the body of the script I'm thinking about …
more seriously -- things I often want to do are such as "for all selected<moho item>" and there are a few examples of these in the code snippets section. Recognising the scale of this challenge - do you have plans to enable items in code snippets to be configurable and then dropped into the code?? That would be a tremendous next step!
Wow, that's amazing!
The problem is that such a loop can be inserted into many thing - the Run method, the HandleMessage method, on mouse/keyboard events, even multiple times... So, I cannot really picture how this can be handled in a convenient way. Any ideas, anyone?hayasidist wrote:more seriously -- things I often want to do are such as "for all selected<moho item>" and there are a few examples of these in the code snippets section. Recognising the scale of this challenge - do you have plans to enable items in code snippets to be configurable and then dropped into the code?? That would be a tremendous next step!
Maybe just add an "Insert" dropdown that lists all the code snippets under each Keyboard/Mouse Controls function. You'd want to show the Run function for button/menu scripts, and probably see about having a new "Insert" dropdown appear after one's been used. No idea how hard that may be to do.
I can't seem to delete the first GUI element I add.
