Animating a wormhole?
braj
Re: Animating a wormhole?
Post by braj »
OK, this is the last quick test before bed, I set one of every layer to ADD layer blending mode, then created a new layer outside all the wormhole layers with a gradient radial with transparent inside, black outside, and set it to Hue. I need to basically redo the whole thing with some more unique renders, this is all based on one image rotated randomly then put through the wormhole treatment, I am guessing 4 unique layers with no random spin would keep the cycle from being a bit jumpy when restarting. But this was an AWESOME learning experience, and great fun. This is just the MP4 output from ASP, no composting with blur effects and stuff like the original. ASP is pretty awesome for this sort of stuff, once you get how to approach it. I think this came out rather well:
https://dl.dropboxusercontent.com/u/930 ... rmhole.mp4
DK
Post by DK »
Nice effect braj. Definitely pass for a wormhole or even a large intestine :lol:
Cheers
D.K
BooDavi
Post by BooDavi »
Hi guys, I tried following the instructions provided in the posts above, but I just couldn't get it to work. I couldn't figure out where the Y angle was or how to change it. Can you guys explain it with a little bit more detail? I might have missed something.
chucky
Post by chucky »
standard stuff. x= across, y=up/down , z= forward back.
Use your hand to remember x yz thumb index middle. = RGB ,red, green ,blue= xyz is another helper you will often
BooDavi
Post by BooDavi »
Ok, so the confusing part comes from this image:
slowtiger wrote:Image
In this image, it appears (To me) that by changing the Y angle, the layers can be placed behind each other, or (Away from the camera) which would be the job of the Z angle. But when I change the Y angles of the images to multiples of 3, as mentioned in the instructions, I end up with one image slightly higher than the other image, not placed behind it. So In my mind, in order to get the effect shown on the picture, I need to change the Z angle, but I don't get how to curve it. I'm sorry if I'm a bother, I just really would like to make this effect and you guys are the only source I could find.
The Z angle would only rotate the image, like a wheel. To stack stuff in Z space, you need to rotate around X or Y.
Just remember: the Z axis is the camera view.
DK
Post by DK »
Hi Chucky,
According to Lightwave (See Screenshot Below)
The 3D Axis are displayed from the front or camera view in matching colours as follows.
Your diagram indicates the Y axis stretching out in front of the camera following along the
index finger or am I reading it incorrectly?
Cheers
D.K
DK wrote:Your diagram indicates the Y axis stretching out in front of the camera following along the
I read it that the middle finger was pointing at the viewer/camera.
DK
Post by DK »
It looks like the X axis is going upwards with thumb pointing upwards? That's supposed to be the Y axis on the verticle.
Maybe I am reading it wrong?
D.K
chucky
Post by chucky »
Oh maybe I posted a dodgy image. This replaced an earlier link that was inordinately huuuuuge.
x is a cross, how about that ? I hadn't heard it before but I can't have made that up as I am pretty much incapable of originality.
You're right -- x is a cross!
chucky
Post by chucky »
Also Y points down
jezjones29
Post by jezjones29 »
I know it's a bit late, but this is kind of related.. it's a way to show something moving through a wormhole :)
http://www.animestudiotutor.com/shared_files?id=232
DK
Post by DK »
That's amazing.
Can you share the file?
EDIT: Got the file and it's the best solution I have seen for this effect.
Well done!
D.K
jezjones29
D.K. You can download it from that link.
