Funny you should say that it is for Lyrics.( So a script would be handy.) I have a software called FRAMES that will do text like this but saves out as a QUICKTIME Mov file with transparency which of course won't import to Anime studio Pro 11 because of Bit depth. (not 64) other wise it would be great.
Script needed typing text.
- uncle808us
Re: Script needed typing text.
Took me 20 minutes to do. So there's no need for a script unless you want to show a whole book this way.[/quote]
export as images from QUICKTIME does not work either. So..... This is why I was looking for a script. Thanks for all your help but this would just take too long for what I had in mind.
http://uncle808s.blogspot.com
- Víctor Paredes
I have both AS 32 and 64. If you I need to use or export to quicktime, I just open the 32 bit version. Be sure you installed both versions.uncle808us wrote:Took me 20 minutes to do. So there's no need for a script unless you want to show a whole book this way.
Funny you should say that it is for Lyrics.( So a script would be handy.) I have a software called FRAMES that will do text like this but saves out as a QUICKTIME Mov file with transparency which of course won't import to Anime studio Pro 11 because of Bit depth. (not 64) other wise it would be great.export as images from QUICKTIME does not work either. So..... This is why I was looking for a script. Thanks for all your help but this would just take too long for what I had in mind.
I think videos with alpha are imported, but maybe the alpha won't be shown until you render it.
- uncle808us
Where can I get Anime studio Pro 11 in 32 Bit? I didn't think I could.
- Víctor Paredes
The installer has both versions. During the installation you must check "install the 32 bit version" (or something similar).uncle808us wrote:Where can I get Anime studio Pro 11 in 32 Bit? I didn't think I could.
- uncle808us
Just re downloaded the installer for Anime Studio Pro and there was no choice to install a 32 bit version.
Here are the Mac specs:Macintosh
Macintosh® OS X 10.8, 10.9, 10.10
64-bit OS required
1.3 GHz Intel Processor or newer
2 GB RAM recommended
800 MB free hard drive space minimum
1024x768 display (1280x800 recommended)
DVD-ROM drive (physical version only)
Internet connection required for periodic product activation service
64-bit OS required
- Víctor Paredes
Oh, sorry, didn't see you are on a mac (and it was right there in your signature).
I don't know much about Macs, but I thought the Quicktime problem was Windows exclusive. I'm sorry, I can't help you with that.
- uncle808us
Not a problem, Thanks for trying.
- uncle808us
Solution for me anyway: as for the Frames software it will export to gif then I open that in gimp (the gif has a transparent background) then from Gimp I export as layers(script) then in Anime Studio 11 using script( image sequence) import. Finally there it is typing with a Transparent BG. fantastic and now I can use all the great text effects in Frames. by passing QT. Thanks for all the help and effort from everyone who helped me.
