That will work, just make sure that you create the action while the parent group/bone layer is selected...
all you have to do is drag a layer to a different position on any frame other than 0 (once the 'enable animated layer order' (or whatever it's called) is enabled) - this will create a keyframe on the timeline.
Need Help With Animating Shape Stack Order
- funksmaname
Re: Need Help With Animating Shape Stack Order
Can someone show me where exaclty is that option i dont see it in Anime Studio 10funksmaname wrote:...once the 'enable animated layer order' (or whatever it's called) is enabled...
//EDIT i found it
Double click on bone layer or group layer and select "allow animated layer effect" checkbox, after that "depthBox" tab appears whene u can select "enabled animated layer order"
- hayasidist
animated shape order is coming soon in AS11 (Pro version)....
along with a few other exciting new features... watch this space
