stomped by line width
Re: stomped by line width
sceech wrote:Once you know you are going to be using a Group Layer to house a bunch of parts, it's best to create all the new sublayers while working within the Group, which prevents the "all bets are off scenario". The "quick fix" for elements of a drawing is to select the offending points and just scale all of the lines larger / smaller with the "Scale Points Tool" to match the desired surrounding points, then be careful in the future with scaling Layers and drag all your Vector Layers into the Group Layer at once. Been in that hell myself, I guess we're not all saints.
Good Luck!
Once I used a calculator to change line widths to match based on layer scaling. :shock:
I assure you I only made that mistake once. ;)
