My best script ever! Animated text and titles
chucky
Re: My best script ever! Animated text and titles
Post by chucky »
Ronbo wrote:Many thanks, chucky! Very cool script. I didn't know about unchecking create one shape and create text layer. (Nice icon also!)
Oh BTW I got the button to work now, not sure how.
Hey , this was all (Hey)Vern's creation, he's done an amazing job.
arfa
Post by arfa »
one of the biggest "bangs for the buck" I have found for a while. Considering its free - thats a BIG one... Maybe a swirly, spiral blow away one?
Many thanks Vern.
Droxon
Post by Droxon »
omg! Today I discovered this script is so awesome.
Thanks man for creating such a great script for anime studio.
Droxon
Post by Droxon »
Can someone tell me how to animate each letter like in the sample?
I can anime the words/phrases but not each letter.
Thanks in advance :)
RichardU
Post by RichardU »
Droxon wrote:Can someone tell me how to animate each letter like in the sample?
When you create the text, unclick Create One Shape.
Droxon
Post by Droxon »
I knew i was missing something (x
Thanks a lot richard :)
Droxon
Post by Droxon »
I have another quick question, how can I make start at a different frame? (not at 0)
Droxon wrote:I have another quick question, how can I make start at a different frame? (not at 0)
The only way to do that is to make sure you create the spinning text layers inside a group or bone layer. Then you can use the Sequencer and shift the group layer forward to where you want the effect to start.
Depending on the "direction" of the effect you will need to set visibility keys before shifting the group layer. For example, if the text starts "off screen" and spins into view you will need to set some visibility key frames. Shifting the group layer forward will make frame 0 "visible" before it spins into view.
To do this, before shifting the group layer forward, set the visibility of the group layer OFF on frame 0. Then key visibility ON on frame 1. Now you can shift the layer forward in the time line and it will appear correct. The frame 0 visibility key frame works "backwards" when shifting layers with the sequencer. The frame 0 visibility will keep that frame invisible until it is keyed visible on the layer's frame 1.
If the text is ON screen and then animates OFF screen (Blow Away preset), this extra visibility step is not required because the final text position is visible when starting.
Hope this helps. It's actually easier to do than it sounds. :)
Droxon
Post by Droxon »
heyvern wrote: Hope this helps. It's actually easier to do than it sounds. :)
Yes it was so easy :) THANK YOU! I really like this script, now i'll be available to work faster because I used to animate all the text in after effects but it's painfull slow even on my faster computer but now I can do it all in anime studio :D
Droxon wrote:I really like this script, now i'll be available to work faster because I used to animate all the text in after effects but it's painfull slow even on my faster computer but now I can do it all in anime studio :D
That is exactly why I created it. I couldn't figure out how to animate text in After Effects. It just didn't make any sense and was to difficult to get what I wanted. I tried and just couldn't get really cool fancy stuff easily and quickly. This script gave me exactly what I wanted really fast and easy.
djwaterman
Post by djwaterman »
Is it possible to re-link this script. it seems pretty useful for Mo-graph type work. Or is it available somewhere else?
ulrik
Post by ulrik »
djwaterman wrote:Is it possible to re-link this script. it seems pretty useful for Mo-graph type work. Or is it available somewhere else?
You can find it here, and some other scripts by "Heyvern"
http://hubumedia.com/anime-studio-scripts
/Ulrik
onurdemirsoy
Post by onurdemirsoy »
I think you blacklisted my country, Turkey so I cant reach your website. Is it possible to put the file here?
Fil
Post by Fil »
Very interesting script. Thank you very much.
Fil
Post by Fil »
Where there is a function Create One Shape (at Moho 11 PRO) please?
