Offset cycle (UPDATE: Now supports bone locking)
I tried it with both mac and pc in version 8. The script is working only with layer transformations but not with bone transformations in anime studio 8. Maybe you are using the script for layer transformations in version 8. I tried the script with the 7th version, it works fine there for both layer and bone transformations. I tried to make an offsetting walk cycle with combination of capricorn33's fkik script and your offset bone script. Without your script I couldnt make an offsetting cycle, instead I moved the feet's ik bones manually throughout the scene. The problem is when you have to change something you have to make it all over again. I hope your script would be updated for bone transformations in the 8th version. With combination of your script and ikfk script you only make the characters feet walk for one cycle and offset that for the rest of the way. Then you can concentrate on the posture and body movements while the character is walking automatically. And making corrections would be very easy since all you have to do is making adjustments for the feet's original walk cycle. Thanks for your reply.
- uncle808us
Re: Offset cycle (UPDATE: Now supports bone locking)
What if you just want the loop to go to a certain point and no further and keep repeating (looping that path)? So it doesn't move out of frame. Should I just use cycle? Thanks
http://uncle808s.blogspot.com
