Would a particle layer fix this problem?
3deeguy
Post by 3deeguy »
'Prof' slowtiger, that's amazing! It looks 3D. Thank you for everything that you do.
Cheers, Larry
ofcourse ST, i was being slow :P
Btw, I think the flickering blur is due to the layer origin? recently (ponysmasher i think) found a way to get around it... i think...
again, not tried.
No, this flicker definitely stems from AS' unability to do a smooth interpolation between 0 px blur and 1 px blur.
that sucks. :P
3deeguy
Post by 3deeguy »
I'm just glad that after several hours of tinkering with slowtiger's file I was finally able to get a test to loop properly. There were no keyframes to study except for the tracking camera. "How does this thing work?!"I scrubbed the timeline, colored one of the layers purple, unchecked visibility... Thanks for supplying a file that I could study!
Cheers, Larry
Of course there was no keys except for the camera - we built a set and wanted to move the camera in it!
Glad that it worked out for you. I really like discussions like this because I always learn more about my own perception of a program or problem in contrast to others', and about careful wording of descriptions.
3deeguy
Post by 3deeguy »
ST, I will refer to your method as the "Slowtiger oscillating camera technique" unless there is a better way to characterize it. It is tailor-made for complex scenes such as moving along roads, fences, poles etc. I think there are a good many possibilities.
I posted a clip which is jumpy but I know how to eliminate that. I just wanted to see if I could animate on this loop.
http://www.youtube.com/watch?v=8YEC_oe3sSI
Cheers, Larry
To clarify: it's good enough for creating a looping background. To put something else into the scene, like a car or a plane, it saves time to render the loop as video, and import it into the new scene with the plane.
3deeguy
Post by 3deeguy »
What is the plane?
Cheers, Larry
jonbo
Post by jonbo »
Slowtiger means whatever object/character you want in the scene. By rendering the loop and then adding the object/character to a new scene with the loop, it keeps things from getting messy (you won't have to worry about the camera messing up the placement of objects and such)
3deeguy
Post by 3deeguy »
I have always imported new objects into a file. I've never tried to import anything into a rendered video. How is that done? (Please bear with me)
Cheers, Larry
jonbo
Post by jonbo »
you don't import directly into the video, but rather use the video as a background for your character much like a green screen is used. it's a good technique i've used a bunch.
3deeguy
Post by 3deeguy »
Aha! I know what you mean. I've been frustrated when I've assembled separate files into a sequence. I lose all my camera work.
Wow. I've just learned a bunch in this post. I will use the rest of the day to assimilate everything.
Cheers, Larry
