Frame by frame idea
ulrik
Post by ulrik »
It works fine here with LM freehand tool AS Pro 6.1 on OSX
ulrik wrote:It works fine here with LM freehand tool AS Pro 6.1 on OSX
Weird. I'll have to take a look at my scripts. Anyway, it's good news, Is just me, so it can be fixed :)
meltedtoons
Post by meltedtoons »
i do have a custom freehand tool but i donno if it's Fazek's could u give me the link?
meltedtoons
wow this topic is really dead....
meltedtoons wrote:i do have a custom freehand tool but i donno if it's Fazek's could u give me the link?
Take a look on scripting section, there is a sticky called forum members scripts, there you will find fazek's tools.
meltedtoons
wow! Never knew you could do onion skins with switch layers! Take a look:
http://my.smithmicro.com/tutorials/1952.html
Shepard
Post by Shepard »
I don't understand what does this mod... The steps is right?
1. in frame 1, I draw my animation
2. in frame 2, I hold the script's button and I draw my animation
3. in frame 3, I hold the script's button and I draw my animation
But I don't see any difference among the classic animation frame by frame...
Shepard wrote:But I don't see any difference among the classic animation frame by frame...
That's exactly the idea.
selgin, after using this button the first time, any lines I draw default to a transparent colour - am i missing something in the workflow? it works great, except I have to manually correct the alpha for any new drawings so it takes the freedom away...
gravly
failed aspro 6 for linux
Post by gravly »
hi all
This wouldn't work for me aspro 6 under linux. Anyone have some ideas where I would start looking to patch up the code or should I just look for another fbf method?
Zwei
Post by Zwei »
Does this script work on 8.1?
remind me to make a cool code later :P
DocZagreus
Post by DocZagreus »
Hello,
I'm sorry to bother you but I can't understand what I'm doing wrong...
I'm using Anime Studio Pro 8.0 and I'm not able to draw a new frame.
I try to explain what problem I have. On frame 0 I draw a vector layer with a face with no pupils. On the second vector I draw two pupils. Then I move to frame 3, I select the pupils' layer and click the script icon. The pupils are deleted (of course) but I don't have the drawing tool that allow me to draw the new ones.
What am I doing wrong?
Help me please -.-
jonbo
Post by jonbo »
Hey Doc, go to the edit sub-menu, and select preferences. Make sure the "enable drawing tools only on frame zero" option is Not checked.
DocZagreus
Thank you very much :D
You've saved me ^^
Rainer
Post by Rainer »
Zwei wrote:Does this script work on 8.1?
It's not working for me in 8.1 (Win7). Anyone?
