:::::::::Animated Avatar Club:::::::::::
- Víctor Paredes
No need to share the anme files, but it's always nice when people contribute to the community. I'm thinking about a week should be long enough for this to run. If anyone thinks it should go longer, I'm open to suggestions.
And for the record, this brilliant idea was DK's. I just happen to start up the topic.
I think multiple entries should be fine, I'll just judge based on the one I think is the best from each member. If your entry is the one you're using currently, there's no need to post it in a reply. I'll assume anyone who posts in this thread to be entered. (Except for Vern, unless he posts an AS avatar.)
A few tips:
Looping avatar gifs that look continuous (the end matches the beginning) always look more impressive.
The loops should continue forever, instead of ending.
Just some things to keep in mind.
This is great. We already have some animated avatars from members that didn't have one before.
A few tips:
Acochran_89
Acochran_89
Re: :::::::::Animated Avatar Club:::::::::::
I'll start working on it soon.synthsin75 wrote:...J.Baker,
I'd love to see your frog avatar animated....
Oh and if anyone uses Gimp, here's how to do it in Gimp...
Export as images from AnimeStudio.
Open Gimp.
File, Open as Layers...
Select all images by holding SHIFT and select Open
Resize to 80 x 80 (Lanczos 3)
Image, Mode, Indexed...
Floyed-Steinberg (reduced color bleeding) and select Convert
File, Save As... (whatever,gif)
Save as Animation and select Export
Loop Forever
Set the milliseconds (fps / 1000)
One frame per layer (replace)
Use delay entered above for all frames
Save
- Víctor Paredes
- Víctor Paredes
here's another one.
(ok, colors and transparency aren't helping here)
Last edited by Víctor Paredes on Wed Apr 29, 2009 8:57 pm, edited 3 times in total.
GRRRRRR!
Acochran_89, Wow funny how your still avatar, changed to a spinning eyeball, on a green background no less, sometime after I posted my 'avacup' avatar which has a spinning eyeball on a green background.
I'm not one for flaming people around here, but, why have you done this?
Are you perhaps a little strange?
I'm at a loss and pretty disillusioned - wotup?
Exsqueeze me Charles!
I need you over in This Character Rig thread to discuss good practice, shooting me down and stamping out the flames, you banana!
Acochran_89
chucky,
well, the idea from the spinning eyeball came from yours. I saw it was like...well that's cool...then i combined it with B.O.B from monsters vs aliens and had its eye pop out and an arm catch it.....however the green bg was coincidence....i'm actually color blind so i honestly didn't realize yours was green. I can change it...i'm not trying to make ppl mad..just having fun. Everyone bases ideas off other things they see.
