Maskless Eye
DK, just wanted to say thanks to this very helpful technique. It made it easier to have complete eyelid control.
I uploaded a short test animation with my character with a new pair of eyelids I did modify it a bit though. I added a 3rd bone to the top and bottom layers of the eyelids. The 3rd one controls the top (or bottom) vector point and is the root bone for both the side bones. This way I can rotate the eyelids to make it angry or sad (near the end of the test). It was hard to rotate it with out it cuz it would distort the overall shape.
http://www.youtube.com/watch?v=nApC9Bg6kFU
I'll try to post a pic of it if any body wants. Just don't know a good site for pic posting.
Only when his owner misbehaves. I'm having some issues with it. That line that is in the middle of the body won't go away. I've tried to hide it/unhide, but no luck. I might have to redo the body. Oh well, its all trial and error, and maybe for a different post.
and thanks for the comments, I worked really hard on rigging him.
This is all kinda cool, but, and I hate to be negative, why are these eyelids falling like guillotines?
I have never seen an eye in real life that does anything like this.
I know this is a stylised cartoon but this image looks painfully flat.
By fixing the outer edges of the eyelids to the bones the eyes drop like sash windows, they should rather join at a common point , the centre of the lid should be the part that is raising and lowering.
I have been seeing this FLAT eye thing all over this forum and I'm starting to lose patience with it as I see it more and more.
DK you know I respect your work but what,s up with that?
Not to just be a lazy knocker I am backing up today,s rant with a couple of images.
Wow that was quick,
I know this method has problems , but I rushed this out just for the corner of the eye issue.
There are no masks here, and I used bone blinks just to stay close to the topic.
blinker file
blinker file
Here's an even simpler solution for all you guillotine eye haters
All thanks to the chuckster for this one....works on two bines using bone scaling.
and just in time for the movie
http://www.wienertoonz.com/DKEYE2.swf
http://www.wienertoonz.com/DKEYE2.anme
EDIT: This eye rig has only 2 bones that control both eyelids via the main "control" bone using the "Scale Bone" tool and is all totally automated.
Cheers
D.K
Cheers
D.K
- toonertime
Nice solution DK, and great critique Chucky.
That's why this forum rocks. It must be sad working in other apps that don't have such a wonderful place to find inspiration for solving these kind of animation tasks.
Tooner, the only reason he used a switch layer is because you only really need a maskless eye for a single layer solution to work in a switch. Check out the parenting and constraints of the bones, and pull the points apart to see the details of construction.
I had to pull the points apart myself to see.
- toonertime
- toonertime
