new features
DarthFurby
Layer reordering wasn't high on my list of feature requests because of the depth sorting trick. I would've rather seen something that genuinely added new functionality like the image texture effect, although I'm still glad to have layer reordering anyway as it is easier and less confusing than the alternative. Layer based motion pathing was already possible in 5.5, except that now you can adjust the entire path from anywhere on the timeline instead of having to move the cursor to a specific frame to do the same thing.
So here's how I rate the new features:
1) Image texture effect - this is a bona fide new feature, the first we've seen in about 2 years.
2) Layer Motion Path - a reasonable improvement over the old method.
3) Layer Re-ordering - already possible with depth sorting, but easier and less confusing.
slice11217
What is "animated shape stack order"? Please explain..thanks.synthsin75 wrote:That's what I'd REALLY want. I'd love to work with fewer layers, and animated shape order would go a long way to fixing that.Genete wrote:What it would be worthy feature addition were animatable shape stack order.
I'd say this one is number one on my feature request list!
S
Within one vector layer, each shape has an order in which it is displayed. If shapes overlap, you will see the shapes stacking upon each other. The order in which they stack (which is on top of the other) is called the shape stacking order. You can change this order with the Lower and Raise shape buttons in the Fills section of the Tools palette. However, you cannot change it during the animation with keys in the Timeline palette. It is not (yet) an animateable feature.slice11217 wrote:What is "animated shape stack order"? Please explain..thanks.
temujin143
temujin143
- Víctor Paredes
slice11217
