Please send suggestions for my scriptwriting
- gr33ndaybd
cekilinbendoktorum
Re: Please send suggestions for my scriptwriting
Are Fazek's tools available for v9.2? I can't find them.
On http://www.animestudioscripts.com it says they're for v8.
- capricorn33
Lukas wrote:Are Fazek's tools available for v9.2? I can't find them.
I made a fast fix for AS 9.1 earlier, most things should be OK ...
(except for the replace line tool which has some issues)
Should probably work well with AS9.2 as well. (Dunno tho, haven't tested it.)
https://dl.dropbox.com/u/19247240/Fazek ... corn33.zip
tell me if it's not working.
capricorn ( - just call me "cap")
children's tv pro, character animator
- 707dragon707
it would be great if you could make your tools dissappear when they're not needed. Like when your on a bone or switch layer they still appear.
You can. It's the IsRelevant() function.707dragon707 wrote:it would be great if you could make your tools dissappear when they're not needed. Like when your on a bone or switch layer they still appear.
- hayasidist
... I think the OP was hoping that someone would update Fazek's tools to do so...synthsin75 wrote:You can. It's the IsRelevant() function.707dragon707 wrote:it would be great if you could make your tools disappear when they're not needed.
@707dragon707 - Fazek hasn't been active here for a long time (last post I can find is from March 2007)
- 707dragon707
if 2 more things would be great
1st. adding the flip buttons the lm tools have.
2nd.and with the add points tool the disable autoweld does not work,and theres no highlighter where your curser is.
btw since fazek hasent been active for so long should i post these elsewhere.
- 707dragon707
Thanks that helped, and i was able to fix all of the fazek tools and few others also.synthsin75 wrote:You can. It's the IsRelevant() function.707dragon707 wrote:it would be great if you could make your tools dissappear when they're not needed. Like when your on a bone or switch layer they still appear.
707dragon707 wrote:Thanks that helped, and i was able to fix all of the fazek tools and few others also.synthsin75 wrote:You can. It's the IsRelevant() function.707dragon707 wrote:it would be great if you could make your tools dissappear when they're not needed. Like when your on a bone or switch layer they still appear.
Same here, thank's for the hint Wes!
I also still use some of the Fazek's tools, I try to work without them once but that was the short experiment.
Fazek's translate points tool is my favorite, except the advanced selecting (laso/rectangle, add/release points from selection) it can select multiple shapes and change colors. And the translate bones is also there but without moving they children which I find very helpful on frame "0". For example if you want to translate some root bone of character but you don't want to move the arm and the leg bones.
Fazek's bind points tool is also cool because you can bind points to a bone anywhere on the timeline.
Oops, sorry, I made mistake, this above is not true, native bind points tool in V10 can do that, not the Fazek's.Onionskin wrote: Fazek's bind points tool is also cool because you can bind points to a bone anywhere on the timeline.
