Lost·AS·Tools (LostLayerTool, LDT, LostWiggleTool...)
Lukas
Re: Lost·AS·Tools (LostLayerTool, LDT, LostWiggleTool...)
Post by Lukas »
Hi again,
Any chance of an update for 9.5?
Especially the lost layer tool, I get some lua errors every now and then, but still use it a lot anyway.
Rai López
Post by Rai López »
Hi, Lukas and sorry for all the mess, ideally... some day I'll be able (to be able) to manage all this things as I should...
Anyway, and straight to the point, are (by chance) something like follows the kind of Lua Console errors you are experiencing?:
...Anime Studio Pro\scripts\tool\rl_lost_layer_tool.lua:2227:error in function 'SetValue'.
    argument #3 is 'nil' ; '[no object]' expected.
There could be more, but that's what I'm getting in my tries with the last "official" release of the tool (v20100708_1931_rc2) on Windows 7 and Anime Studio Pro 9.5. FYI, it uses to happen when a non Vector layer (Image, Audio or 3D, for example) is selected in palette.
Well... it's complicated to me to face up bigger tool changes right now due to the way I used to manage this projects (and specially this one) in the past but, in that precise error case, I think I can make a quick & dirty fix and upload it here for the moment, and see if we can avoid at least as much Lua Console errors as possible. Greetings.
PS: Besides all that... hmmm, I think I'm a little surprised you still find this precise tool useful since last Anime Studio improvements on Layer settings management by its now modeless "Layer Settings" window and Layers palette RMB direct masking access and mode indicators :o
Rai López
Post by Rai López »
Anyway, here is the direct link to the file I've been (or I hope so) fixing:
This is only the lua file, as nothing else required changes to be made. Just overwrite the old one in the "scripts/tool" folder (previous backup just in case) and... well, that's all for now. Just, let me know whatever you consider appropriate.
Greetings,
Ramón López.
foundmarble
Post by foundmarble »
I have 9.5 and still use your Lost Layer tool.
I use the mouse capture feature a lot.
Thanks for the update!
Lukas
Post by Lukas »
Ramón López wrote:Hi, Lukas and sorry for all the mess, ideally... some day I'll be able (to be able) to manage all this things as I should...
Cool, thanks!
I use it mostly for quick acces to the masking settings, I like how you can change the settings of a layer without having to set the group to 'hide/reveal' first etc. Also for some rigs with complicated masks I sometimes have to set layers to 'add to mask' without using masking on the group they are in (it's weird, but it works). And I like how you can easily set a layer to invisible (the keyframeable one).
Onionskin
Post by Onionskin »
Thanks Ramón, I also still use LostLayerTool
Rai López
Post by Rai López »
Well thanks to all of you for the feedback! It's good to know... About the tool itself, lets see is any other issue arises for a period of time and, if that's not the case, I think I could update the download links with a fixed version at least. Greetings!
chucky
Post by chucky »
Thanks Ramon, I also use Lost layer more than you could know. :D
Deepurana749
Post by Deepurana749 »
dear isr first of all thanx for that amazing tool but inside the layer effects settings there is popup dialogue so that we can manage the affect and particle tool is no hilighted how to fix this Image
Deepurana749
dear isr first of all thanx for that amazing tool but inside the layer effects settings there is no popup dialogue so that we can manage the affect how to fix this Image
lucasfranca
Post by lucasfranca »
Any chance you can bring that back to Moho 14?
https://youtube.com/animai2D
lucasfranca
Lost Wiggle Tool is similar Maybe what Procreate Dreams is offering, I may be mistaken.
