Page 3 of 3
Re: Tween machine (DONE)
Posted: Tue Sep 28, 2021 5:04 am
by Lukas
I took the liberty and made some adjustments!
All my ideas mentioned above are implemented and the slider has been separated from Alexandra Evseeva's Keys Tool for clarity's sake.
While scrubbing the timeline the slider now estimates a percentage so you get a sense of a starting point before you start adjusting the tween.
While dragging the slider the new pose is now previewed in the viewport. When you let go of the mouse it sets a key. The preview makes a huge difference because it's now less trial and error.
You can still set the percentage by typing it in the field, just hit 'enter' instead of the 'OK' button.
Here's the link:
Posted: Tue Sep 28, 2021 9:01 am
by davoodice2
Lukas wrote: ↑Tue Sep 28, 2021 5:04 am I took the liberty and made some adjustments!
Here's the link:
nice work.great!
I think ok button must exist. some time we want to just click ok because percentage in fine for many situations. And a option to disable live preview should be a good thing
I added this to first post.
Re: DV Tween Machine v1.0
Posted: Mon Jan 03, 2022 5:30 am
by davoodice2
New Edition Released.
Posted: Wed Jun 01, 2022 4:47 am
by Daxel
Here's the link:
Thanks for this mod! I'm liking the expanded options a lot, like only timeline visible layers, use step intervals, etc. But the "only selected bones" option doesn't seem to be working, and prevents child layers from being animated even if the "include child layers" and or the "time visible child layers only" are enabled.
Posted: Wed Jun 01, 2022 4:56 am
by KuzKuz
I often use this script in animation. Very comfortably. Just wanted to say thank you!
Posted: Wed Jun 01, 2022 6:26 am
by davoodice2
thanks all. I don't know if this works on references layers for you.
Posted: Wed Jun 01, 2022 8:51 am
by Daxel
davoodice2 wrote: ↑Sat Sep 04, 2021 1:10 am This is my previous Tween machine script with some improvements.
DOWNLOAD
https://www.mediafire.com/file/dlv71283 ... 1.rar/file
I tried using this other version but I get the error "DV_TweenMachine.lua:646: attempt to perform arithmetic on local 'valN' (a string value)".
Posted: Wed Jun 01, 2022 10:43 am
by lucasfranca
I need to learn to use this script. Does anyone have a tutorial?
Posted: Wed Jun 01, 2022 2:05 pm
by Daxel
lucasfranca wrote: ↑Wed Jun 01, 2022 10:43 am I need to learn to use this script. Does anyone have a tutorial?
Yep. Not mine. The script is one of my favourites. Hoping for a built in. One can dream.
Posted: Wed Jan 11, 2023 4:02 pm
by Noob_krusher3000
Daxel wrote: ↑Wed Jun 01, 2022 8:51 am
DOWNLOAD
Did you find a solution for that error? I'm getting the same thing. It worked twice, but then decided to dish out error messages every time I attempted to create an extreme. Please Help...
Posted: Fri Jan 13, 2023 1:59 am
by Daxel
Noob_krusher3000 wrote: ↑Wed Jan 11, 2023 4:02 pm
Nope, sadly I didn't manage to solve the issue or get any info about it.
Posted: Fri Jan 13, 2023 11:44 am
by davoodice2
DOWNLOAD
you have to have key before and after of current frame.
Posted: Fri Jan 13, 2023 12:52 pm
by Daxel
davoodice2 wrote: ↑Fri Jan 13, 2023 11:44 am
I already knew that but I still downloaded the latest version from mohoscripts.com to try it and right now I'm not getting that error for some reason. I still can't make the "only selected bones" option work. Every bone is affected by it. Does that option work on your computer?
Now I tried lukas version and it's giving me this error: LK_TweenMachine.lua:557: attempt to perform aritmetic on local 'valN' (a boolean value) and it doesn't work.
Posted: Fri Jan 13, 2023 2:37 pm
by Noob_krusher3000
That's not good. The thing is, it's given me errors in different projects on different devices, but even after giving me an error, it still performed fine... This time, on a fresh installation it finally decides to fall apart. I love this script, I hope it can be fixed.
Posted: Mon Jan 16, 2023 8:39 am
by lucasfranca
Please, I was curious to know the rest of this image, it seems to me a very beautiful production. Can you share?
