bone dynamics in a particule layer
Posted: Wed Jan 26, 2005 12:32 am
by jim hawkins
please, how to apply bone dynamics to objects when then are grouped in a particule layer? it was working before grouping them...
Posted: Wed Jan 26, 2005 2:10 am
by Lost Marble
Short answer: you can't.
Longer answer: the dynamics simulation is not compatible with particle layers. Because each sub-layer in a particle group appears multiple times in the final particle effect, the bone layers would have to be running a different dynamics simulation for each particle.
The problem is that right now a layer doesn't know or care if it is being used as a particle or not. So, a bone layer only maintains a single dynamics simulation.
This could change in the future so that a separate dynamics simulation is being run for each particle, but it makes the design "messier", since a bone layer needs to use different logic if it's in a particle group or not.
