Replicate without overlap
Posted: Sat May 04, 2024 2:47 am
by Nicohk92
I'm trying to get a shape replicated at controllable intervals, or at least with enough control so that they are somewhat evenly spread around without superimposing onto each other.
What would be fantastic would be a tool that can distribute instances of a shape on each points of another shape (there's a geometry node like that in Blender, or a similar effect in Apple Motion called Replicator).
I tried doing it with those green crosses using a particle layer, but no matter the settings, they keep overlapping. If at least I could have them not being on top of each other. Maybe with a brush?
I can't believe I may have to resort to another software to achieve something that simple.
Re: Replicate without overlap
Posted: Sat May 04, 2024 3:18 am
by hayasidist
two ways I can readily think of:
scatter brush -- draw your cross (any size); select the shape and copy; then set the scatter brush _options_ to be all zeros except Spacing which you set to greater than 1: about 1.5 to 2 worked well for the quick test I ran. Set the max and min sizes to be the size you want (e.g. 75 px); then drag the mouse around -- yes, ok, you need to avoid running into a previous shape you've created.
custom brush: set the spacing to be more than 100%, draw lines -- you may need to tweak some point placements because the brush stamps might overlap when you get to a control point.
hope that helps
Posted: Sat May 04, 2024 4:13 am
by Nicohk92
I didn't think about scatter brush.
I still think I'll use an outside motion design software for more control here.
A scatter to points tool would be a really good addition to MOHO in my opinion.
Posted: Sat May 04, 2024 4:35 am
by hayasidist
Nicohk92 wrote: ↑Sat May 04, 2024 4:13 am A scatter to points tool would be a really good addition to MOHO in my opinion.
e.g. replicate a (copied) shape on each of the selected points?
Posted: Sat May 04, 2024 5:36 am
by Nicohk92
Yeah, a copied or designated shape (or layer) to all selected points
Posted: Fri May 10, 2024 10:31 pm
by 570295535
Are you looking for this script? After all, it's been a long time, but it can still work on moho14.1:
https://mohoscripts.com/script/sz_layer_copies
