adding an outline in Moho 5
Posted: Thu Oct 14, 2004 9:02 pm
by DK
What is the correct way add just an outline to a shape in Moho 5
now that the old outline tool has changed?
D.K
Posted: Thu Oct 14, 2004 9:19 pm
by DK
This must sound stupid....but i'm stumped...i actually just want to draw a simple line with no fill????? How do i do this in Moho5???
D.K
Posted: Thu Oct 14, 2004 10:01 pm
by kdiddy13
With the create shape tool, select your shape, press the space bar. In the style window, uncheck outline or fill. This should create the shape you want.
________
Design Host
Posted: Thu Oct 14, 2004 10:07 pm
by DK
Thanks for the rsponse but it's not a shape outline i want to make....it's just a simple unjoined line that i want to create from points?
D.K
Posted: Thu Oct 14, 2004 10:11 pm
by 7feet
2 ways. One is to set you're defaults in the style panel, and then fill the checkbox for Auto Outline if you are drawing using the Freehand tool.
The other is to select the Create Shape tool, select the points you want to outline, and when you hit the spacebar you'll assign you're default settings to the line
If you need more specific info, give a yell.
--Brian
Posted: Thu Oct 14, 2004 10:15 pm
by DK
Hey thanks Brian.....for some reason i was using the shape fill tool and spacebar but nothing was happening....i just managed to do it then by starting up a new Moho file....thanks for the replies
D.K
