SS - Number Sequence
Posted: Thu Jul 13, 2023 11:03 am
by SimplSam
Quickly create animated number sequences
(An update to the built-in number sequence menu script)
Enhanced Features:
+ Specify Start and End of sequence
+ Starts from current frame
+ Specify Count and/or Frame Interval
+ Forward or Reverse numbers (Low-to-High, High-to-Low)
+ Option to Display leading zeros
+ Sequence is created in a Switch Layer
Latest release: https://mohoscripts.com/script/ss_number_sequence
Re: SS - Number Sequence
Posted: Thu Jul 13, 2023 11:40 am
Nice!
For number counters, I always imported an image sequence I created in my compositing program. That works but if I need to change it, I need to go back to my compositing program and create a variation. SS - Number Sequence should make these extra steps unnecessary.
Will give it a try tonight! Thanks for creating and sharing another useful tool SimplSam. :D
Posted: Thu Jul 13, 2023 3:12 pm
by DK
Another useful enhancement to Moho that should be integrated into the next release.
Thank you so much.
Cheers
D.K
Posted: Thu Jul 13, 2023 4:05 pm
by DK
Hi SimpleSam.
Just to let you know it is working great except for one thing...I selected "leading zero's" but
the script doesn't generate them. It shows them in the display area but doesn't add them to
the final readout.
Cheers
D.K
Posted: Thu Jul 13, 2023 6:54 pm
by SimplSam
DK wrote: ↑Thu Jul 13, 2023 4:05 pm ...I selected "leading zero's" but the script doesn't generate them. It shows them in the display area but doesn't add them to the final readout.
What are your number ranges? It takes the max number of digits in the sequence and makes all numbers that wide by padding with leading zeros - if necessary.
i.e.
10 - 54 you will not see leading zeros
2 - 16 you will (02 ... 09)
80 - 120 you will (080 .. 099)
101 - 999 you will not
Posted: Thu Jul 13, 2023 7:18 pm
by DK
Ahhh...that makes sense. I was just testing it with small ranges 1-20 etc.
Thanks for the explanation and also the fantastic improvement SimpleSam!!!
Double Cheers :D
D.K
