3D Texture Bug (SOLVED)
Posted: Sun Aug 29, 2021 5:02 am
Hi.
I've not been around for a bit. Been in hospital but well enough to start creating with Moho again and found what I think is a bug.
If you 3D lathe out an object and surface it with an image texture you get this really bad image noise happening when it's animated.
The only way I could reduce the effect was to split the curves but it didn't go away just got a little less jittery.
Cheers
D.K
Cheers
D.K
