Using PNG or TIFF
Posted: Wed Mar 03, 2021 4:48 pm
by Albo
Hi,
Using Moho 11.
When I import PNG's and TIFF images is it possible to add bones to the images.
I can't seem to be able.
Thanks.
Re: Using PNG or TIFF
Posted: Wed Mar 03, 2021 8:27 pm
Sure, it should work.
In ASP 11, imported images are bound with Flexi-bind by default.
Note that an image layer is only be affected if the layer is a child layer of a Bone layer, so make sure the images are actually inside the Bone layer and not just sitting under the Bone layer. Also, your bones need to have strength above 0 (it should already have some strength unless you intentionally reduced it to zero.) Another thing you can check is that Warp Using Bones is enabled in the image layer's settings. (This should be enabled by default.)
Finally, you can try selecting all your image layers and choosing Reset All Bone Rigging from the Bone menu. This will reset the layers to Flexi-bind. (Of course, any image layer still needs to be a child layers of a Bone layer to be deformed by bones.)
If none of the above solves the issue, it would help to see a screen cap of your setup, or a project file demonstrating the issue.
Posted: Wed Mar 03, 2021 10:13 pm
by Franky1966
Hello Albo
Did you put the images in a Bonelayer? That should do the trick.
Posted: Sat Mar 06, 2021 6:06 am
by Albo
Thank you both.
I will try this out and keep you posted.
