				Has anyone recorded a crescendo and decrescendo on Garageband’s song?
				Posted: Wed Feb 19, 2020 11:22 am
				by stevepappas452
				I am using Garageband for a long time. I want the sound to be decreased and increased without me modifying it, on a song I recorded on GB. Is there a solution to this?
				Re: Has anyone recorded a crescendo and decrescendo on Garageband’s song?
				Posted: Wed Feb 19, 2020 12:51 pm
				by jahnocli
				Well, if I'm understanding you correctly, I'd import the file into Audacity. It's easy in that software.
				Posted: Thu Feb 20, 2020 2:17 am
				There should be an option to record the mixer movements you do, search manual.
				Posted: Mon Feb 24, 2020 1:01 pm
				by Felainum1977
				You can surely automate the increase as well as decrease of volume on your track. You just need to click on the display main track option that you will find under then track menu. This should allow you to have that functionality.
This is why I prefer Garageband as my DAW, but as of now, I am not able to use it. As I am using windows I am not able to run it there. Do you know how this can be done?
				Posted: Mon Feb 24, 2020 11:09 pm
				by stevepappas452
				jahnocli wrote: ↑Wed Feb 19, 2020 12:51 pm
Okay I will try it in audacity app
				Posted: Tue Feb 25, 2020 10:42 am
				by cyclearrows
				I'm using Cubase for a long time. I have Cubase Elements which costs around 100$. I also tested the Pro version and there is nothing I miss in Elements. I also tried Garage Band and I found it quite similar to Cubase.
				Posted: Wed Feb 26, 2020 11:28 am
				by stevepappas452
				cyclearrows wrote: ↑Tue Feb 25, 2020 10:42 am
Thanks Mate
				Posted: Wed Feb 26, 2020 11:55 am
				by cyclearrows
				You are welcome.
				Posted: Fri May 15, 2020 10:59 pm
				by adjessica
				stevepappas452 wrote: ↑Mon Feb 24, 2020 11:11 pm
Felainum1977 wrote: ↑Mon Feb 24, 2020 1:01 pm
Hey @Felainum1977 , I will do it.
There are many DWA apps available for windows. But if you want to use Garageband app for windows, then you need to follow some methods as garageband is macOS app. You need to install any third party application such as VMware or Virtual Box to use garageband app. I found this article on the internet where steps are well explained. Cheers!
https://thegaragebandpc.com/
Garageband is also available for pc? WOw!
				Posted: Mon Jul 04, 2022 1:01 am
				by stevepappas452
				adjessica wrote: ↑Fri May 15, 2020 10:59 pm
Yes, Garageband can be used in windows. But you need to create a virtual MacOS environment in your PC. It can be some by macOs simulators available online.
However, Now i'm thinking to upgrade my monitor setup and purchase a widesceen monitor? I am thinking to go with LG 34WN80C-B monitor. it widescreen and curved dispay.
Found this monitor works well for music production and boost the produtivity.
https://trustedmonitors.com/best-monito ... roduction/
What do you guys think? investing on good monitor will really helpful? Any suggestions should be appriciated. Thanks.
