Can a script select a layer?
Posted: Thu Jan 17, 2019 2:09 am
by Víctor Paredes
There are four or five layers I need to constantly select (in a project with hundreds), do you know if there's a way to select a layer using a button script in the tool palette?
I'm thinking on this idea:
- Put a "selection1" tag in the layer I want to select
- Have a button in the tool bar which every time I press it, it will select the layer with the "selection1" tag (I could also add a shortcut for it)
Since I have room in my tools palette, I could have several buttons referring to different tags.
Do you think that is possible?
Re: Can a script select a layer?
Posted: Thu Jan 17, 2019 2:57 am
by hayasidist
yes -- there's a script interface command ScriptInterface:SetSelLayer(layer, multiSelect, allowDeselect) -- scan the layers for the required tag and use it!..
e.g.
function hs_sel_by_tag (moho, tag)
		if not tag then return end
		local i = 0
		repeat
			layer = moho.document:LayerByAbsoluteID(i)
			if layer then
				i = i + 1
				if layer:UserTags() == tag  then -- or contains string (e.g. use string.find)  or ..
					moho:SetSelLayer(layer) -- (or for multiselect (layer,true) and no following "break"
					break
				end
			end
		until not layer
		return
end
What I'd do is put the above into a file as utility function i.e. hs_sel_by_tag.lua goes in the utility folder
(that core code has been tested -- but it doesn't look to see if there are multiple layers with the same tag -- many ways to address that -- e.g. multi-select; or flag an error; or start from the last selected and move on rather than always start at 0; or .. depends on what you exactly want)
and the guts of the buttons are
local required_tagname = <whatever>
hs_sel_by_tag (moho, required_tagname)
you could (additionally) have a "general" button that asked the user for the required tag
Stan's new script generator should take the strain out of that!
hope that's helpful.
Posted: Thu Jan 17, 2019 9:56 am
Not sure if this is exactly what you have in mind, but try this out, Victor: https://sites.google.com/site/synthsin/ ... ects=0&d=1
With this tool selected, if the first layer tag is a single-character (and available as a shortcut in Moho), hitting that key will select that layer.
It's up to the user to make sure the shortcuts they use are available and not duplicated, and uppercase (shift+key) and lowercase are separate shortcuts.
Posted: Thu Jan 17, 2019 10:13 am
by Víctor Paredes
hayasidist wrote:yes -- there's a script interface command ScriptInterface:SetSelLayer(layer, multiSelect, allowDeselect) -- scan the layers for the required tag and use it!
Thank you very much, hayasidist!
This will be very useful for me.
synthsin75 wrote:Not sure if this is exactly what you have in mind, but try this out, Victor: https://sites.google.com/site/synthsin/ ... ects=0&d=1
Wes, this is just fantastic! Thank you very very much! I will start creating all my rigs with this tool in mind!
Posted: Mon Jan 21, 2019 11:36 am
I've vastly improved this tool.
Same link: https://sites.google.com/site/synthsin/ ... ects=0&d=1
Full description here: viewtopic.php?f=12&t=32641
Posted: Thu Feb 07, 2019 8:19 am
I was just thinking there should be an easier way to select deeply nested layers, like an editable/clickable list of frequently selected layers or something like that. Then I remembered this thread.
Will give the script a try today. Sounds like it might do what I need. :)
Posted: Thu Feb 07, 2019 9:02 am
Hopefully it's a bit faster than opening and scrolling through a list of layers.
