heyvern's old hm_switch_commander script
Posted: Tue Feb 20, 2018 10:35 pm
by coatsiecoates
Does anyone have a copy of this, or know where to get it?? The link to where he kept it on the Hubu Media page is not valid anymore.
Re: heyvern's old hm_switch_commander script
Posted: Wed Feb 21, 2018 1:57 am
by DK
You could possibly contact him here. His avatar is still on the front page.
https://www.hubumedia.com/
Cheers
D.K
Posted: Wed Feb 21, 2018 3:54 am
by chucky
I found Vern's switch layer bone control script . Would that do it?
Posted: Wed Feb 21, 2018 4:26 am
by coatsiecoates
The script he did that I'm looking for assigns ctrl + 0-9 to each of the phonemes in a mouth switch layer.
I have a ShuttlePRO V2 and want to assign a button to each sound so I can use the scrub wheel and buttons to fly through lip sync.
...that is, unless someone's finally devised a way to completely automate it reliably.
...OR knows of another way of assigning a key command to a switch layer.
Thanks!
Posted: Fri Feb 23, 2018 4:23 am
by jezjones29
I don't have the original, only a tweaked version I use. I think this is what you're after. It works with Moho 12.4
https://www.animestudiotutor.com/link/528/
(I have removed a lot of my code to make it as close to the original as possible)
Posted: Fri Feb 23, 2018 10:22 am
by velu
jezjones29 wrote:I don't have the original, only a tweaked version I use. I think this is what you're after. It works with Moho 12.4
Great script!
Is there same this script for bone layer (lips)?
Posted: Sun Aug 05, 2018 2:11 pm
by Monkey Possum
I'm trying to use this script. I have the switch selector set up. The script "Switch Layer Plus 1.1" appears in Scripts / Tools pulldown menu. It is grayed out unless I select the mouth layer, so I select the mouth layer. I choose the script.
What do I do now?
