Loop switches in Switchlayer [script]
Posted: Mon Feb 06, 2006 7:02 am
by rylleman
Here's another switch script, similar to my Random Switch script, (forum thread).
Loop Switch Script --Right click to download.
Usage: Select a Switch layer and run the script.
The switches in the layer will then be layed out in the timeline following their layer order.
The parameters you can set is start and end frame in the range, interval between the keyframes,
and you can also select to lay out the keyframes in reverse, starting with the last switch, going downards in the list.
If the switches reaches the last one before the range has reached it's end they will start over from the beginning.
Posted: Mon Feb 06, 2006 1:12 pm
by bupaje
Thanks for the cool addition -and the other as I missed it first time around- should be useful. :)
Posted: Tue Feb 07, 2006 3:02 am
by Rai López
YEAH! THANK YOU TOO for my part!I must experiment more with both scripts, but... listen, do you think an addition of a text box to specify which Swith layer you want add randomnly in time? I think could be interesting... BYE!
Posted: Tue Feb 07, 2006 3:59 am
by rylleman
Ramón López wrote:listen, do you think an addition of a text box to specify which Swith layer you want add randomnly in time?
Actually I have thought of that. I just haven't figured out a way to do it...
I'm planning on combining both switch scripts into one and add some other features as well, selecting which layers to include is one of them.
Posted: Tue Feb 07, 2006 6:37 am
by Rai López
...EY, EY, EY,!!! THAT'S SO GREAT!!! :D THANK YOU for add funcionality! I think something like that could be very USEFUL for me actually :), and... yeah! Combine the scripts in only one is always a good idea if possible! GOOD LUCK! :D
Posted: Tue Feb 07, 2006 9:37 am
by ulrik
Thanks Rylleman for your usefull scripts! :D
Posted: Thu Dec 11, 2008 11:27 am
by rylleman
Small update on this script.
You can now also set to use every # image in the sequence.
Setting it to 3 for instance would use images 1,4,7,10 etc.
Posted: Thu Dec 11, 2008 2:19 pm
by DK
Great script!!! Thanks rylleman :)
D.K
Posted: Sun Apr 05, 2009 8:02 am
by paulcopeland
Wow what a great little script.
Thank you.
Paul.
