The new Image Sequence layers are not meant for svg import, since these layers wouldn't allow for vector editing (so you could just export your svg to a raster format). Even the old third-party image sequence import menu script didn't handle svg. I can write an svg sequence import script that will keyframe each in a switch.
Re: Moho 12 & CACANi
Posted: Thu Aug 04, 2016 2:35 pm
by dueyftw
synthsin75 wrote:The new Image Sequence layers are not meant for svg import, since these layers wouldn't allow for vector editing (so you could just export your svg to a raster format). Even the old third-party image sequence import menu script didn't handle svg. I can write an svg sequence import script that will keyframe each in a switch.
