v5.3 render problem
Posted: Mon Dec 05, 2005 11:38 pm
by Sine
I'm having problem rendering avi in V5.3.
After rendering the last frame, MOHO disappears on me and leaves me with a broken avi. Anyone else experiencing this?
Using XP pro.
Posted: Tue Dec 06, 2005 12:35 am
by T
Did a very simple animation test, rendered 72 frames as AVI with "Full Frames Uncompressed", and it worked fine.
Are you using compression? If so, which?
Posted: Tue Dec 06, 2005 2:33 am
by Sine
Found out what went wrong. I had a wav file sountrack that MOHO didn't like. Previously, I could even load an avi as a soundtrack but v5.3 will only take wav. I had to rip the audio from the avi and since the avi was a DV footage, the wav file was a 48KHz 16bit stereo format. Downsampling it to 44KHz and below solved the problem.
Thanks for trying it out.
