Following the tutes: p95, Rotation (ASP 9.2)
Posted: Wed Dec 11, 2013 10:07 pm
by JericRoM
I'm following the default tutorial and on p95 it says to use the Layer Transform Angle setting to rotate layer #5 (building a cube). Up to this point all the steps in the tutorial have worked fine, but entering a 90 in the Angle setting has no effect.
Obviously the layer should rotate around the X axis. What might make this NOT happen?
Thanks!
