				Script: Weld all points within radius.
				Posted: Tue May 24, 2005 1:48 pm
				by Nichod
				Perhaps this function exists, or this is a script somewhere that does this. But occasionally I'm having problems with an imported file that I want to fill and it won't fill properly because of some obscure point that wasn't connected. Would be nice to have a function where we could select all and then use the tool and it would weld all points together by proximity.
Brian
				Posted: Tue May 24, 2005 5:39 pm
				by myles
				Brian,
have a look at Scripts; Other; Auto Weld. Hopefully it should do just what you're after (although I think you may have to edit the script to change the default proximity radius).
Regards, Myles.
				Posted: Tue May 24, 2005 6:44 pm
				by Nichod
				Yeah I discovered this
  a bit after posting this. Would be nice to have the script edited to have a box to control the distance of the weld. Would give it more uses. Need to play with scripting at some point.
