Working with Blend Morphs and locked bone tip from "Sel
Posted: Wed Aug 19, 2009 12:30 pm
by ulrik
Working with Blend Morphs and locked bone tip from "Selgin" when making walk cycle, thanks Selgin!!
http://www.youtube.com/watch?v=AdRizFVSq4k
Posted: Thu Aug 20, 2009 6:22 pm
by jackass
Good like how it looks natural in movements and not stiff like must anime studio flims I see.
Posted: Fri Aug 21, 2009 12:27 am
by ulrik
Thanks for comments! :)
Posted: Fri Aug 21, 2009 1:42 am
by Genete
What I love really is the imagination to create those funny shorts. The backgrounds are pretty cool and the character movement is fuid.
I only miss a bit of more expressions on his face.
:D
Posted: Fri Aug 21, 2009 1:59 am
by ulrik
Genete wrote: I only miss a bit of more expressions on his face.
:D
You're right Genete, this character is under construction and I have the mouth left to do, I'm working on how to build it so that I can use lipsync without interference from the headturn (using blend morph), I have not figured it out yet.
thanks for commenting! :)
Posted: Fri Aug 21, 2009 7:51 am
by VĂ­ctor Paredes
ulrik wrote:I'm working on how to build it so that I can use lipsync without interference from the headturn (using blend morph), I have not figured it out yet.
viewtopic.php?p=77099#77099
Take a look on that thread. You actually can make a character talking and turning using blend morph, just give to each mouth each pose you made, then blend.
Posted: Fri Aug 21, 2009 9:17 am
by ulrik
This was the tread that made me start exploring Blend Morphs :D
The thing with my lipsyncing is that I use point motion for the mouth in my headturn, which means that I can't use point motion for lipsyncing so I have to use bones and I have not yet found the best way to do this.
bones for lip syncing
Posted: Fri Aug 21, 2009 10:58 am
by Vagabond
ulrik wrote:The thing with my lipsyncing is that I use point motion for the mouth in my headturn, which means that I can't use point motion for lipsyncing so I have to use bones and I have not yet found the best way to do this.
Me too but I think that blend morphs are only in ASP6 so I've been looking for a thread that explains how to do expressions with bones. I've seen examples of rigs with control bones on the side and would like to modify it for lipsync too. I think you could use a bone to turn the head too. I purchased the manual and I've done all the tutorials I could find and I'm still... uh... clueless.
I duplicate my mouth layer a bunch of times and put them in a switch layer then use point motion for the phonemes. I link the soundtrack and a lot of keyframes populate the timeline. Then I have to manually clean up and move the different keys. I think moving bones at the right frame would be less tedious.
any ideas?
