Page 2 of 2
Re: Script for switching multiple switches simultaneously
Posted: Sat Sep 02, 2017 9:24 am
by hayasidist
ok
so...
function Script(moho)
-- are we a switch layer on frame 0? N: abort
-- find a child .MASTER [?find first only?? check all and report error if >1??] [or assume first child is MASTER??] [or active child is MASTER?]
-- for each layer in .MASTER [i.e. every layer, irrespective of depth -- or will immediate children be OK?]
-- 	[or would it be better if just some (relevant) layers in MASTER are identified as "controlling" layers]
--	for each child of switch that is not .MASTER [aka slave child] [assume slave if not MASTER]
--		for each layer in slave child [again - all layers or just immediate child layers?]
--			if slave child layer name == .MASTER layer name
--				set slave child layer visibility to that of .MASTER
-- end if; end for; end for; end for
end
((If that's the right idea then I'd be seriously tempted to make that a button script rather than a layer script since it's set-up only))
Posted: Sat Sep 02, 2017 9:50 am
by chucky
Ha ! that looks awesome!
I always prefer a button to embedding, so if you think it'll work then that would be so good.
So the recipe , could it be as simple as , toggle invisibility of all named the same as selected, inside the Master?
Posted: Sun Sep 03, 2017 3:19 am
by hayasidist
chucky wrote:...So the recipe , could it be as simple as , toggle invisibility of all named the same as selected, inside the Master?
that suggests that you'd select a layer in master (e.g. thin lips) - set its visibility and run a script to set all others of the same name --- so you'd need to run this as many times as you have different layers - but yes could be.
Posted: Sun Sep 03, 2017 7:16 am
by Stan
Just an idea. You can have a tool script that will have some functionality running within the IsRelevant or IsEnabled method - that will run automatically every time something changes in the Layers panel. You can also have a checkbox (i.e. a boolean) in the tool's panel to turn that functionality on and off.
Posted: Sun Sep 03, 2017 9:41 am
by hayasidist
We've got a beta doing some behind the scenes iterations right now -- should be fit for public consumption in the next couple of days.
Just to whet the appetite: This is designed for use in set-up where the same structure has many options from which a one-time choice is made at set-up (e.g. same phoneme switch for many mouths - all the phonemes have all the mouth shapes - but only one is to be visible).
-- there's one "leader" switch child (per main option) and this holds things that have their visibility _manually_ toggled on or off
-- all the other switch children get their copy of the things made visible / invisible at the click of a tool button (or the execution of a menu item)
Stan wrote:Just an idea. You can have a tool script that will have some functionality running within the IsRelevant or IsEnabled method ...
Now that is an interesting use of those routines! Hmmm ... cogs whirr ...
Posted: Sun Sep 03, 2017 11:49 am
Yeah, I've used those for my auto-save script. These are called whenever you enter/leave frame zero, change a tool, change a layer, and maybe a few other things.
Posted: Sun Sep 03, 2017 8:08 pm
by chucky
Well, I can vouch for Paul's beta so for. It does an amazing job and has already saved me a lot of time and effort, Also my file is so much neater now. I can also make changes and additions without it getting bogged down with duplicates, references and all the malarkey.
Thanks hayasidist :D
Posted: Mon Sep 04, 2017 5:07 am
by hayasidist
here it is: https://www.mediafire.com/file/uxu0vb95 ... Switch.zip
The zip file contains:
- the script .lua file
- an icon .png file
- an example .moho file (created in moho 12.3)
- readme.txt
Installation - you can put the .lua as a menu item (e.g. the <custom folder>\scripts\menu\Visibility) or along with its icon in the tool folder <custom folder>\scripts\tool
Note that this is a "set-up" script not an animation script.
any bugs etc - please say!!
[edit] this is now V2.00
activate on any group type in any parent structure -- the visibility of that group's children is propagated to children of the same name in all groups in parent
