Smooth Head and Body Turns
Posted: Mon Sep 10, 2007 12:46 pm
by superanimatrix
Hi guys, How do I get those smooth head turns and body turns?
Posted: Mon Sep 10, 2007 1:21 pm
You animate them by hand. The more drawings, the smoother the movement will be. You could either pre-fabricate the phases of a head turn and put them into a switch layer, or you could do a frame-by-frame point aninmation, or you spend some time to build a rig as described elsewhere which could do a decent smooth head turn in a limited range but will only work for certain styles.
Posted: Mon Sep 10, 2007 1:28 pm
by superanimatrix
slowtiger wrote:You animate them by hand. The more drawings, the smoother the movement will be. You could either pre-fabricate the phases of a head turn and put them into a switch layer, or you could do a frame-by-frame point aninmation, or you spend some time to build a rig as described elsewhere which could do a decent smooth head turn in a limited range but will only work for certain styles.
I have not learned what a switch layer is yet. I'm just starting out!
Posted: Mon Sep 10, 2007 1:51 pm
by Genete
For head turns also watch DarthFurby's video tutorials. There are tree videos and uses actions to perform head turn. (Tips and Techniques sub forum).
Also don't loose ***Resources*** sticky post in same sub forum. Lots of interesting threads there.
Posted: Mon Sep 10, 2007 3:24 pm
by superanimatrix
Genete wrote:For head turns also watch DarthFurby's video tutorials. There are tree videos and uses actions to perform head turn. (Tips and Techniques sub forum).
Do you have the links to those? or did you already give em to me?
Posted: Mon Sep 10, 2007 3:28 pm
by Genete
viewtopic.php?t=8301
viewtopic.php?t=8525
viewtopic.php?t=8867
And ***Resources*** is a sticky thread at the beginning of Tips & Techniques sub forum.
Now you have a LOT to watch and read. :wink:
Posted: Mon Sep 10, 2007 3:43 pm
by superanimatrix
Genete wrote:viewtopic.php?t=8301
Are you having any problems with the links to the lessons? When I click those links to the lessons the pages are blank!
Posted: Mon Sep 10, 2007 3:50 pm
by Genete
No. For me the links work perfectly.
Anyway all they are at Tips & Techniques sub forum as I said before. Just read the writer of the original post and search for DarthFurby.
Posted: Mon Sep 10, 2007 5:02 pm
by superanimatrix
Genete wrote:No. For me the links work perfectly.
Ok, I will do that. Maybe the video is taing a while to download. I have another question, I am woring on my first character (The Greek One) I made is head too big and need to make it smaller so I can draw in the torso, how do I do this? Also can I make the stage bigger?
Posted: Tue Sep 11, 2007 1:21 am
by jahnocli
Please don't post the same question in different places.
