Crash with import audio files. Hlep me, please!!!
Posted: Wed Sep 05, 2007 9:31 am
by yafar
I can´t import audio files for lip sync.
Sometimes works and sometimes crash.
I´m using a wave sound file with IMA ADPCM
compression, and without compression too.
What can i do ?. :(
With papagayo 1.2, the other alternative, I have other problems:
I can´t import audio files, only the tutorial files works good.
I can´t save the projects either.
Note: I have a Pc with XP.
Sorry for my bad english.
Thanks!!!
Posted: Thu Sep 06, 2007 5:28 pm
by myles
Hello Yafar,
right-click on the tutorial audio files in Windows Explorer and select Properties from the context menu. Look on the Summary tab (if you see an Advanced button on the summary tab, click on it).
You can see all the tutorial files included with Papagayo are mono and use PCM format (no compression), and use either 16K or 11K bitrate, and a sample size of either 8-bit or 16-bit.
You could try converting your files to use the same settings.
A number of forum members successfully use the freeware Audacity to do their audio conversion and some audio processing. Use Edit > Preferences in Audacity to change sound settings and/or the drop down menu in the name bar to the left of a loaded wav file.
Try not to use any non-ASCII characters in the file names or paths.
C:\sounds\myfile.wav is good.
C:\söûnds\myfilè.wav might not be.
Regards, Myles.
Posted: Fri Sep 07, 2007 1:42 am
by yafar
Thank you Myles. I try it with Audacity.
Thank you very much.
Regards, Yafar.
