point by point hall
Posted: Mon Jun 18, 2007 2:28 pm
by AlanPS
I'm trying some cool perspective stuff with point-by-point switch layers. You could use this principal for buildings, boxes, etc.
What I'm attempting (and asking help for) is the look you get when you're in the middle of a hallway that extends in either direction. When you rotate to your left or right there's almost a fisheye effect that takes place (at least on the movies) which I can't accomplish at the moment.
Also I'm sure my perspective is totally incorrect but if someone tweaks this it will look really cool and I will submit it for anyone's use. It would also be cool if people run with this idea and we could start a library of hallways, buildings, etc. for public domain using this effect.
Some lines in the switch layers are also totally not needed but this is my first attempt.
http://www.mediafire.com/?b9he9tnxdwn
Posted: Mon Jun 18, 2007 3:52 pm
by Genete
It looks cool!
Regarding to technical questions:
There are three kind of perspectives drawings: one point, two points and three points.
All parallel lines will confluence in its corresponding vanishing point.
In your animation the vanishing point is not correct most or the time. That's the reason why it not seems true conic projection. During transformation between a layer and its partner inside the switch layer the parallel lines should converge to the vanishing point.
Maybe you better do it only with point potion and later try to achieve it by switch layers changes. Sometimes the interpolation done is not the desired one...
Check out
conic perspective basics for more information.
Best
Posted: Tue Jun 19, 2007 2:20 am
Take a trip to the local library and have a look for books about M.C. Escher (some listed here:
http://amazon.com/s/ref=nb_ss_gw/105-36 ... .y=6&Go=Go). Especially the volume "The magic mirror of MCE" by Bruno Ernst has some construction grids which are useful for the kind of effect you described.
I tried to find some panoramic images from interiours on google, but the nearest I found was this:
. You can already study the different perspective lines here: the room is a perfect rectangle.
Posted: Tue Jun 19, 2007 8:22 am
by Mikdog
Nice !
Re: point by point hall
Posted: Tue Jun 19, 2007 8:34 am
by human
AlanPS wrote:I'm trying some cool perspective stuff with point-by-point switch layers. You could use this principal for buildings, boxes, etc.
Hey. that IS cool. Thanks for sharing.
thanks
Posted: Tue Jun 19, 2007 1:49 pm
by AlanPS
I've been borrowing so much from everybody on the forum- it feels cool to contribute at least a potentially workable idea.
deck the halls with fisheye lenses- fa la la la la...
Posted: Wed Jun 20, 2007 2:03 pm
by AlanPS
Got two new versions. I believe I've fixed the first perspective point, I just can't quite figure out the other.
To get the fisheye effect I added some points to the curve and scaled them up. Still totally incorrect scientifically but it looks a little better. Didn't know if some of the curves are supposed to be convex as opposed to concave (though at the moment I can't remember which is which).
http://www.mediafire.com/?3lzmu35cne5
http://www.mediafire.com/?c4mmy9xmizz
