Another realistic 3D eye experiment
Posted: Sat Jun 16, 2007 2:30 am
by Genete
Re: Another realistic 3D eye experiment
Posted: Sat Jun 16, 2007 10:11 am
by human
Genete wrote:I like experimenting. 8)
I'm not sure if you're deliberately working toward an exaggerated anime style with small irises, but if you want to use this nice model for a realistic character, consider making the iris larger.
Posted: Sat Jun 16, 2007 10:53 am
by Genete
Like always you're right.
I'll try to correct it.
Also I have problems to place the bright in the proper place...
Any ideas?
Thanks
EDITED:
The size of the iris was corrected. Thanks to the ability of morphing the shapes in 3D it have not been so difficult. The anme file have been updated.
Also consider this swf only for bright position...
It is very difficult to achieve a realistic one...
http://darthfurby.com/genete/Other/eye/eye.swf
All help is welcome.
Thanks again
Posted: Sat Jun 16, 2007 2:17 pm
by funksmaname
Nice going Genete . :)
I think the new eye is looking much better than the first... could you not mask the 'bright' that pops out of the eyeball? its placement would look fine if you did i think...
Anyway - you probably thought of that!
Good luck with your other experiments mad professor!
Posted: Sat Jun 16, 2007 3:31 pm
by Genete
funksmaname wrote:Nice going Genete . :)
I don't understand your question properly. Maybe some kind of language limitation from my side... Do you want I show or hide the bright outside the eyeball?. The cornea over the iris is transparent in a real eye. I was trying to simulate it placing bright over it... The big bright is very big. The reflected image in an spheric surface is always smaller than the original. That big bright then should be as big as the sun at the distance of the moon (we all were died ...) It must be much smaller.
Try to come later on it. I was working to put some blood veins around the iris...
Thanks
Ah! now I understand,,, You said mask because the bright position is so far off the eyeball... in fact is bad done the surface where it is is very convex ... A difficult task to correct...
Still learning!!!! :wink:
Posted: Mon Jun 18, 2007 12:12 pm
by slice11217
Actually, since the 'bright' is actually a reflected highlight on the liquid surface of the eye, assuming that the source light is static, the 'bright' wouldn't move much at all as the eye rotates. The 'bright' would either change shape or go up and down in intensity.
