Auto Scripted 3D rig. Files and Video Tutorial
Posted: Fri Jun 15, 2007 11:10 am
ADDED jul-21-2007 and modified on aug-3-2007
UPDATE!
PLEASE BACKUP YOUR ANME FILES BEFORE USE THOSE SCRIPTS. I CANNOT GUARANTEE ANY CRASH SINCE SOME CODE COULD FAIL IN SOME CASES. USE AT YOUR OWN RISK. IT STILL UNDER DEVELOPMENT.
NEEDED FILES HERE:
http://www.darthfurby.com/genete/Script ... ils_v9.zip
It includes updates for :
3Dgrid version 9 and 9.1(this one allows conic perspective but need to fix shape sort - Thanks to Vern's fantastic addition!!)
sort_shapes9.1: some minor bugs fixed and proper usage with multiple limbs.
ge_front_3Drig3.2: Added a window option to make easier the creation of the bones.
Just select the points, and the central bone and call the script. It would take care of create the masters bones, the mX and mY bones, rename the clone bone and place a t the proper position when applicable.
ge_side_3Drig3.1: Properly work with the partner previous script.
AND HERE THE TUTORIAL:
http://www.darthfurby.com/genete/3DrigT ... s/cube.htm (3,4 MB)
http://www.darthfurby.com/genete/3DrigT ... /cube.anme
It is a little rough, but instructive. This tutorial is done with the files above linked. Please place the files 3Dgrid and sort_shapes with the anme file. Please put the ge_front_3Drig and ge_side_3Drig scripts unde a subfolder of the scripts folder of your AS folder installation.
The sample is very simple because I don't want to spend time drawing. In fact the biggest time you'll spend would be drawing the front and side views of your model. The auto rig scripts are very quick.
Remember that Front and Side views must have same points (the front view must be a copy of the side view but with the points in another place. It doesn't matter if the lines are not the same. It could help you to have the same lines or not, depending on the complexity of the model. Remember that if need to add a point to the model you should start over making a copy of the front view layer to create the side view layer. There is a trick: If you add the same points at the same order and do exactly the same operations in both layers, it would produce compatible layers. For that you should morph your model in other frame than frame 0. It would help you to identify lines and points when add the new points to both layers. If the scripts claims for a non existing Rx or Ry bone when rotate it, then something has gone wrong...
There is a known bug in the sort_shapes script:
If you press the raise shape or lower shape repetitively beyond frame 0, it would crash AS. Take care of make a backup frequently.
Have fun!
ADDED: jun-23-2007
NEW VERSION!:
http://darthfurby.com/genete/Scripting/3Drig_utils2.zip
http://darthfurby.com/genete/Scripting/humanoid.swf
CONTENT OF 3Drig_utils2.zip:
3Dgrid9.lua
ge_front_3Drig3.lua
ge_side_3Drig3.lua
humanoid.anme
sort_shapes9.lua
Main changes:
1) ge_front_ 3Drig3.lua and ge_side_3Drig3.lua allow a more easy creation of limbs. Also the helper bones (Rx and Ry) are smaller and its meaning is different. See this post for deeper details. You can tweak them directly over the timeline only with the translate bone tool. Not more use of scale value of the bone, only its relative positions to its parent.
2) Modified version of 3Dgrid (3Dgrid9.lua) to store the Z value of each point. Needed to perform shapes sort.
3) sort_shapes9.lua New script that perform a Z sort of the shapes of the vector layer where it is embedded. Work together with version 9 of 3Dgrid. Corrected some problems of Z sort for limbs that were not considered in the alpha version.
The file humanoid.anme is a simple sample to show how it works. Feel free to play with it. Specially the mX and mY bones (angles) and the .Rx and .Ry bones (positions). Be careful there are a lot of bones. Use heyvern's select bone tool.
I have experienced some lua errors when drag the timebar too fast (and / or reversed in direction) from shape order script. Go to frame 0 and start it over if it happens.
All the scripts need speed up improvements with code optimization. But it would be done in the definitive release.
Let me have a breath until I make the video tutorial. I've been working a lot lately.
Please keep this topic on sight! News soon!
ORIGINAL POST
Hi!
Just taken form the oven I have prepared a video tutorial to explain how work the script that heyvern created with the math I gave him and the automatic 3D riggers scripts that I have created to work all together.
The files needed to make the magic are here:
http://www.darthfurby.com/genete/Script ... _utils.zip
Content of the file:
3Dgrid7.lua
Embedded script that perform the magic of 3D illusion. It is the one that do the loops work on every frame.
3Dgrid7_menu.lua
3Dgrid7_embed.lua
Menu and embedded script that do the same than the previous one. The difference is that they are a little faster because one loop is not needed during animation. Forget them for the moment until a new tutorial is done. They are my experiments.
ge_front_3Dgrid.lua
ge_side_3Dgrid.lua
Menu scripts (can be used as button scripts also) that perform the automatic creation of the needed bones to move the model in the virtual 3D space. Install them just copying in a folder inside AnimeStudio/scripts/menu/Yourfolder/. The created bones are the holders of the 3D information of every point in the model. Modifying the bones created by those scripts can morph the model at frame 0 (to all the animation) or at any frame (animated morph).
The bones created are called by its extension. The name of the bone is automatically created and you should not take care about it. regarding to the extensions the meaning of every extension is:
*.pt : This bone is the one that bind ONE point of the mesh. Are created in the front view. You can modify them and drag the point with the bone. Also you can play moving the point away form the bone to fine tunning the position of the point if needed.
*.Rx: this bone control the distance of the 3d point to the ZY plane. Z is pointing toward to your eyes.. The only useful information from this bone is its scale (effective length). DON'T touch them at frame 0. Do it at frame 1 if you want to morph all the animation. Some of them have a "negative length" if you use the translate tool to modify its length at frame 0 the translate tool would reverse its length to a "positive" one. That makes the model useless. Do it at frame 1.
*.Ry: this bone stores two information. Its length is the minimum length of the 3D point to the X axis. This minimum distance have an angle with the XY plane, that angle is stored at the angle of the bone. So if you modify the angle and the scale of the bone you can modify the model itself. You can do it at frame 0.
Be free to play with those bones to morph your creation.
Also be sure that you create the masterX and masterY bones to perform the overall rotation. If they don't exist there is a lua error.
This tutorial is my first experience with wink
. Please forgive the big length and its boring style. I have realized that wink is a good tool to perform video tutorial. I should have realized it before... If not why myles uses it in his always master lessons?
AND FINALLY HERE THE VIDEO TUTORIAL:
http://www.darthfurby.com/genete/3DrigT ... DBasic.swf
20MB ... I cannot stop give thanks to DarthFurby for his big generous hosting of my files. THANKS!!
I have done it @ 1024x768. Sorry if it don't fit in your screen...
Ah! In the lower right corner there is a arrow button to follow the steps...
For the newbies: My tool palette is customized so some tools are not in the original place.
New tutorial to perform limbs (like the 3D tail) will come soon!
Keep connected!
Cheers!
UPDATE!
NEEDED FILES HERE:
Have fun!
ADDED: jun-23-2007
NEW VERSION!:
3Dgrid9.lua
ge_front_3Drig3.lua
ge_side_3Drig3.lua
humanoid.anme
sort_shapes9.lua
Main changes:
ORIGINAL POST
Hi!
3Dgrid7.lua
3Dgrid7_menu.lua
3Dgrid7_embed.lua
ge_front_3Dgrid.lua
ge_side_3Dgrid.lua
Keep connected!
Cheers!
