Drain vector art fuidly
Posted: Tue May 08, 2007 3:43 pm
I have recently discovered the MegaMagnet tool (I recommend the crashcore modified one here)
It is pretty cool to make fluidly things.
http://genetita.googlepages.com/sumidero2.mov
http://genetita.googlepages.com/sumidero2.anme.zip (the anme file is a little big so I have complressed it)
You can do this animation just adjusting the radius of the megamagnet tool and the strength to your desired values.
Then position the mouse at the center of the drain of the figure and the time cursor at frame 1. Enlarge the project frame end value enough to not to stop the playing of the file.
Press the space bar and also make a left click with the mouse meanwhile the file is playing... Move the mouse meanwhile the left click is held a little (enough to make the megamaget tool work). In this way you will grab the keyframes through the time and all the points will be attracted to the mouse's position like in the example.
That's fun!
That's fun!
