Aligning layers in 3d space
Posted: Sat Mar 03, 2007 9:18 am
by appelgurk
I had to figure out a method of aligning layers in 3d space, so that they appeared on the exact same z value.
Opening the .moho-file in a text-editor and manually copy and paste the desired value worked just fine.
(Z value highlighted in blue).
/Apl
Posted: Mon Mar 05, 2007 3:13 pm
by Genete
The direct numerical input from the traslation layer tool does not work for you????
Regards
Posted: Mon Mar 05, 2007 7:31 pm
by Víctor Paredes
nice png, genete.
(podría ser un gif animado cerrándose, como un Eso es to eso es to eso es todo amigos)
Posted: Mon Mar 05, 2007 11:15 pm
by Genete
selgin wrote:nice png, genete.
Y antes de cerrarse saldria Porky diciendo: Eso es to eso es todo amigos!
appelgurk: Sorry for the off-topic.
Posted: Tue Mar 06, 2007 12:52 am
by Rasheed
Well, in a text editor you can work a lot faster than using Anime Studio. So if you have a lot of alignment to do, this could be a faster method.
I'm thinking of describing the Anime Studio file format for so long, that I'm tempted to finally doing it. The problem is that I then need to write a specialized editor to modify the files outside the Anime Studio program for this to be of any use. Luckily, it is a flat format, instead of a XML format (IMHO a crappy way to serialize your document objects). So, if you know your way around in the Moho file format, it is sometime faster to change your animation in a text editor than in the program itself.
If that isn't a hint for a new feature in Anime Studio, I don't know what is.
Heck, I'll post it right away.
Posted: Tue Mar 06, 2007 3:23 am
by appelgurk
Holy crap!
Funny I haven't seen that before. Still, I agree with Rasheed that editing the file in a text editor is a good option . I also tend to use it a lot when replacing source images.
I'm looking foreward to see that AS file format description.
