View Reset added to the drawing window
trash
Post by trash »
How about adding an icon on the Drawing window to reset the view instead of having to go View -> Reset to reset the View to normal & centered? This is something i do quite often.
Even better yet would be 2 icons, 1 for centered view & 1 for alternate view that saves the last view you used before centering. Anytime you change the view by panning and zooming around the drawing area that gets saved as the alternate view.
-Trash
Lost Marble
Post by Lost Marble »
You can press the Home key on your keyboard instead of using the menu command.
