Water
Posted: Mon Jan 15, 2007 1:56 pm
by ACER
How can I make water in Anime Studio 5?
Posted: Mon Jan 15, 2007 2:20 pm
by Genete
Look here
Posted: Mon Jan 15, 2007 6:12 pm
by bupaje
Also under the menu Scripts you will find one called wavy. You can use this to set up a simple movement and then tweak the individual keyframes a bit more if you want. You can layer several slightly different of these, maybe add some particle effects if you want.
Here you can see an example of simple water done this way in an old test I did.
http://stormvisions.com/moho/fish_swim_1.mov
