Backgrounds
Posted: Tue Jan 02, 2007 4:15 pm
by turminator
Hello!
I'm newbie and now I do this method:
First, I draw my characters with pencil in a paper.
Second, I scan this image and then I import and image layer and draw on with AS
Now I want to do my backgrounds but I don't know how do this.
Which program you recommend for this task?
Thanks!
Hola!
Soy nuevo en el mundo de las animaciones y ahora que ya tengo hechos mis personajes me gustaria realizar los fondos de la animación. Los personajes los hacia escaneando una imagen dibujada a lapiz e importandola como image layer y usar después como plantilla.
Con que programa me recomendais que haga los fondos?
Muchas gracias!
Posted: Tue Jan 02, 2007 4:24 pm
You could draw your backgrounds in AS the same way.
Or you could paint them in a paint program like Photoshop or The Gimp or something similar, save as JPG or PNG and import them into AS as an image layer.
Posted: Tue Jan 02, 2007 5:43 pm
by v_aviles
I use AS for the backgrounds, but I save the different elements (trees, rocks, etc.) as individual files for later use. This way I can import and combine them to create new backgorunds.
Yo uso AS para los fondos, pero guardo los diferentes elementos (árboles, rocas, etc.) para re-usarlos. De esta manera puedo importarlos y combinarlos para crear fondos nuevos.
Posted: Tue Jan 02, 2007 6:47 pm
by Rasheed
Indeed, you can create background the same way you create your characters. They can either be vectors, still images or video clips.
Here is a small very rough example of a moving background and a character using images only:
click on image to view video on YouTube
Posted: Tue Jan 02, 2007 7:00 pm
by turminator
Ok Thanks! The problem that I have when I draw a simple room and I see preview the image (Control+P) don't same that the background that I draw.
I hosted my demo
http://rapidshare.com/files/9917206/room.anme.html
Why happen this?
Thanks!
Gracias por vuestras respuestas! El problema que tengo cuando dibujo las líneas con el programa y luego hago la preview, las lineas no salen iguales. ¿Debo darle formato a cada cosa? ¿Si quiero dar formato a un rectangulo y que el grosor del borde sea el mismo, debo hacerlo a ojo o hay alguna opción mejor?
Muchas gracias!
Posted: Tue Jan 02, 2007 7:08 pm
by v_aviles
Use Render (Control+R) instead of preview...
Posted: Tue Jan 02, 2007 7:10 pm
by turminator
Ok thanks!
Control+P and Control+R is not the same?
Posted: Tue Jan 02, 2007 7:29 pm
by Rasheed
No, previewing and rendering is not the same, and exporting a single frame with transparency is yet another thing, at least, in the Mac OS X version.
(In the Mac OS X version, if you render a frame with Command R and save as a PNG, BMP or Targa image, transparency will be incorrect. This is a know bug since Moho 5.3, and hasn't been removed yet.)
