How to export swf file without looping (play one cycle)?
Posted: Thu Dec 21, 2006 8:59 pm
by alex298
Hello,
I noticed that the exported flash file is looping by default. However I cannot see the option "without looping" when export to flash file. How can I export flash file without looping effect?
Thanks and best regards
Alex
Posted: Thu Dec 21, 2006 11:45 pm
by Rasheed
AFAIK there is only the loop option.
Posted: Fri Dec 22, 2006 1:28 am
by DK
You could export it as an animated gif. A gif is universally read and you can control your loop cycles as well as the timing of each frame.
Merry Christmas too everyone!
D.K
Posted: Fri Dec 22, 2006 2:50 am
by Rasheed
AFAIK AS doesn't have an animated GIF export, only sequential image export in the pro version.
Posted: Fri Dec 22, 2006 2:53 am
by jahnocli
For control of looping within the file you need to import the swf file into Flash and put a stop(); command in the final frame of the timeline. In a browser, you can control playback with the EMBED commands.
Posted: Fri Dec 22, 2006 10:57 am
by Touched
This is correct. SWFs automatically loop unless specifically told not to by a bit of code either inside the SWF or in an HTML page the SWF is embedded into. Anime Studio would need to have the option to insert the stop(); command in the last frame of the SWF, and it doesn't have that.
