lost 3D texture on 3d obj
Posted: Wed Oct 18, 2006 6:17 pm
by theos
Hi!
I load a 3d obj with texture attached to it and it works fine. I animate the obj, and render works. I close the file and re-open it but textures are lost, AS can't find them again even if the map is in the same directory as the AS file. Is this a bug or am I missing something? Cheers for the help.
Posted: Thu Oct 19, 2006 3:59 am
by Víctor Paredes
the same thing happens with some of my files.
Posted: Fri Oct 20, 2006 9:07 am
by theos
OK, found the way. AS is looking for the material file as well as the pictures files of the object in the same folder where the scene you're loading is.
Make sure you have the .mtl file as well as the .jpg or whatever other pic format you have in your scene directory. Hope this helps anybody else.
.mtl files are generated by Zbrush and 3dsmax, the softs I use.
Posted: Fri Oct 20, 2006 10:38 am
by Víctor Paredes
theos wrote:OK, found the way. AS is looking for the material file as well as the pictures files of the object in the same folder where the scene you're loading is.
is don't know well why this happens. i use teddy and chameleon, then i fix the texture with wings3d and export to obj. in the same folder of the project. the texture works well, but suddenly dissapear.
Posted: Fri Oct 20, 2006 11:25 am
by theos
Hi Selgin, sorry to hear this is not solving your problem, I haven't yet encountered the one you are describing. Hope you'll find a way, good luck!
